  4. V8 Swapped E30
V8 Swapped E30
107 Posts 18 Posters 2.3k Views 2 Watching
  • johnprusinskiJ
    johnprusinskiJ
    johnprusinski
    well after a few months of dumping all my money into my VW and other E30, I didn't get anything done on the V8 swap. I tore it down and decided what im going to do for power. I cleaned it up, painted and installed the oil pan. I also ordered a couple gaskets and sensors  that I broke along the way.im also starting to buy the accessories for the front.
    im switching to LS1 accessories so i started by buying a LS1 crank pulley.
    here is a basic idea of what the motor looks like now. i have the motor mounts back on it now.
    i ordered a pedal assembly for the car so when that gets here i can start running lines.
      Is that oil pan made for e30 purposes or just generic ls swap into anything purposes
        Kind of reminds me of a Paul Poore SE30 pan
        http://www.r3vlimited.com/board/showthread.php?t=368336
        • CMartC
          CMartC
          CMart
          Nice progress. I picked up an Cheby V8 E30 recently. I'd love to check this out some time
          Excursion 7.3
          E30 LS1
          • johnprusinskiJ
            johnprusinskiJ
            johnprusinski
            The oil pan is specifically built for LS bassed e30 swaps. I am currently prepping the cab for the cage by getting all of the tar out, which is not fun.
              Dry ice is your friend.
              • johnprusinskiJ
                johnprusinskiJ
                johnprusinski
                I learned that the hard way. It wasn't hard to get the sound deadning out, it was the residue. I used aircraft remover and it worked great, but I should've used dry ice.
                  why did you remove an aircraft from your car?
                    What in 9/11 are you talking about, Snap?
                    • andyhundleyA
                      andyhundleyA
                      andyhundley
                      Jet fuel cant melt sound deadening. #neverforget
                        If removing sound deadening from your E30 causes your skin to fall off
                        youuuuu might be an aircraft.
                          I have a green car.
                          • johnprusinskiJ
                            johnprusinskiJ
                            johnprusinski
                            Ha-ha I like where this is going.
                            • johnprusinskiJ
                              johnprusinskiJ
                              johnprusinski
                              Time for an update. I short of maxed my credit card out to buy a perts to rebuild the head on the black e30 and a cage for the v8 swap. The cage has a pretty huge leed time so I probably won't see that for a few months. I did however get my garagistic brake booster delete bracket. I won't go into details about the scrap they sent me. I also bought my pedals and masters. On February 19th I'll be buying coilovers. I also mounted my resivoirs for the pedals.
                                What cam in the m20?
                                • johnprusinskiJ
                                  johnprusinskiJ
                                  johnprusinski
                                  I bought a 284 degree cam.
                                  • CMartC
                                    CMartC
                                    CMart
                                    Interesting reservoir placement. Any reason they aren't in the bay?
                                    Excursion 7.3
                                    E30 LS1
                                      Keep an eye on the level as you drive maybe?
                                      Would a place let you pass tech with stuff in the cab like that John?
                                        A guy on BF who has a track e21 has his reservoirs in the cabin as well. So I assume it doesn't matter
                                          I've seen them inside plenty of times but never on the outside of the dash. I've only seen them mounted under the dash centrally or right above the pedal box
