  4. V8 Swapped E30
V8 Swapped E30
107 Posts 18 Posters 2.3k Views 2 Watching
    Is that oil pan made for e30 purposes or just generic ls swap into anything purposes
      Kind of reminds me of a Paul Poore SE30 pan
      http://www.r3vlimited.com/board/showthread.php?t=368336
      • CMartC
        CMartC
        CMart
        Nice progress. I picked up an Cheby V8 E30 recently. I'd love to check this out some time
        Excursion 7.3
        E30 LS1
        • johnprusinskiJ
          johnprusinskiJ
          johnprusinski
          The oil pan is specifically built for LS bassed e30 swaps. I am currently prepping the cab for the cage by getting all of the tar out, which is not fun.
            Dry ice is your friend.
            • johnprusinskiJ
              johnprusinskiJ
              johnprusinski
              I learned that the hard way. It wasn't hard to get the sound deadning out, it was the residue. I used aircraft remover and it worked great, but I should've used dry ice.
                why did you remove an aircraft from your car?
                  What in 9/11 are you talking about, Snap?
                  • andyhundleyA
                    andyhundleyA
                    andyhundley
                    Jet fuel cant melt sound deadening. #neverforget
                      If removing sound deadening from your E30 causes your skin to fall off
                      youuuuu might be an aircraft.
                        I have a green car.
                        • johnprusinskiJ
                          johnprusinskiJ
                          johnprusinski
                          Ha-ha I like where this is going.
                          • johnprusinskiJ
                            johnprusinskiJ
                            johnprusinski
                            Time for an update. I short of maxed my credit card out to buy a perts to rebuild the head on the black e30 and a cage for the v8 swap. The cage has a pretty huge leed time so I probably won't see that for a few months. I did however get my garagistic brake booster delete bracket. I won't go into details about the scrap they sent me. I also bought my pedals and masters. On February 19th I'll be buying coilovers. I also mounted my resivoirs for the pedals.
                              What cam in the m20?
                              • johnprusinskiJ
                                johnprusinskiJ
                                johnprusinski
                                I bought a 284 degree cam.
                                • CMartC
                                  CMartC
                                  CMart
                                  Interesting reservoir placement. Any reason they aren't in the bay?
                                  Excursion 7.3
                                  E30 LS1
                                    Keep an eye on the level as you drive maybe?
                                    Would a place let you pass tech with stuff in the cab like that John?
                                      A guy on BF who has a track e21 has his reservoirs in the cabin as well. So I assume it doesn't matter
                                        I've seen them inside plenty of times but never on the outside of the dash. I've only seen them mounted under the dash centrally or right above the pedal box
                                          Might depend on which orgs you run with. Usually tech rules for racing are stricter than DE, and/or more strictly enforced.
                                          There is often the blanket prep rule that if the rules don't say you can do X then you can't do X. The other broad rule that might apply is that hoses in the cabin carrying hot or flammable liquids have to be metal or reinforced (e.g., braided steel for your lines).
