V8 Swapped E30
its going to be a while before I get this thing running and driving. I still have to find a trans and buy the cage for the car. after that I need to figure out a dash, plus a whole interior. I want to hopefully start it and figure out the bay before I paint it. I also have to reinforce the rear end so I don't rip out my diff. I still have a lot, but hopefully I can get it close to finished next year.
Nice. I'm doing a BMW V8 swap so not entirely the same, but if you have any questions or need a hand with anything shoot me a message. I'm over in Milwaukee.
Edit - I just sold a 102MM Fast intake/ported TB, but still have some ls6 injections/fuel rail if you are interested.
Im going to go with an ls3 intake with rails and injectors. Surprisingly the swap is very straight forward, its just affording a trans and wiring that's the only thing that's presenting a problem, but its not too big of a problem.
I took off the intake and wiring harness tonight. I want to take it out to get some work done soon to make it quick and reliable.
I took the time to try and fit the 6.0 in the car the other day. I day to pound out the trans tunnel with a hammer. the combination of beers and a hammer caused my trans tunnel to split and create a hole. I will fix that once I get more gas for the welder. right now it works as of right now, the motor fits in the car.
well after a few months of dumping all my money into my VW and other E30, I didn't get anything done on the V8 swap. I tore it down and decided what im going to do for power. I cleaned it up, painted and installed the oil pan. I also ordered a couple gaskets and sensors that I broke along the way.im also starting to buy the accessories for the front.
im switching to LS1 accessories so i started by buying a LS1 crank pulley.
here is a basic idea of what the motor looks like now. i have the motor mounts back on it now.
i ordered a pedal assembly for the car so when that gets here i can start running lines.
Kind of reminds me of a Paul Poore SE30 pan
The oil pan is specifically built for LS bassed e30 swaps. I am currently prepping the cab for the cage by getting all of the tar out, which is not fun.
Dry ice is your friend.
I learned that the hard way. It wasn't hard to get the sound deadning out, it was the residue. I used aircraft remover and it worked great, but I should've used dry ice.
Jet fuel cant melt sound deadening. #neverforget
Ha-ha I like where this is going.
Time for an update. I short of maxed my credit card out to buy a perts to rebuild the head on the black e30 and a cage for the v8 swap. The cage has a pretty huge leed time so I probably won't see that for a few months. I did however get my garagistic brake booster delete bracket. I won't go into details about the scrap they sent me. I also bought my pedals and masters. On February 19th I'll be buying coilovers. I also mounted my resivoirs for the pedals.
