  4. V8 Swapped E30
V8 Swapped E30
107 Posts 18 Posters 2.3k Views 2 Watching
  • johnprusinskiJ
    johnprusinskiJ
    johnprusinski
    Im going to go with an ls3 intake with rails and injectors. Surprisingly the swap is very straight forward, its just affording a trans and wiring that's the only thing that's presenting a problem, but its not too big of a problem.
    I took off the intake and wiring harness tonight. I want to take it out to get some work done soon to make it quick and reliable.
    • johnprusinskiJ
      johnprusinskiJ
      johnprusinski
      I took the time to try and fit the 6.0 in the car the other day. I day to pound out the trans tunnel with a hammer. the combination of beers and a hammer caused my trans tunnel to split and create a hole. I will fix that once I get more gas for the welder. right now it works as of right now, the motor fits in the car.
      • johnprusinskiJ
        johnprusinskiJ
        johnprusinski
        well after a few months of dumping all my money into my VW and other E30, I didn't get anything done on the V8 swap. I tore it down and decided what im going to do for power. I cleaned it up, painted and installed the oil pan. I also ordered a couple gaskets and sensors  that I broke along the way.im also starting to buy the accessories for the front.
        im switching to LS1 accessories so i started by buying a LS1 crank pulley.
        here is a basic idea of what the motor looks like now. i have the motor mounts back on it now.
        i ordered a pedal assembly for the car so when that gets here i can start running lines.
          Is that oil pan made for e30 purposes or just generic ls swap into anything purposes
            Kind of reminds me of a Paul Poore SE30 pan
            http://www.r3vlimited.com/board/showthread.php?t=368336
            • CMartC
              CMartC
              CMart
              Nice progress. I picked up an Cheby V8 E30 recently. I'd love to check this out some time
              Excursion 7.3
              E30 LS1
              • johnprusinskiJ
                johnprusinskiJ
                johnprusinski
                The oil pan is specifically built for LS bassed e30 swaps. I am currently prepping the cab for the cage by getting all of the tar out, which is not fun.
                  Dry ice is your friend.
                  • johnprusinskiJ
                    johnprusinskiJ
                    johnprusinski
                    I learned that the hard way. It wasn't hard to get the sound deadning out, it was the residue. I used aircraft remover and it worked great, but I should've used dry ice.
                      why did you remove an aircraft from your car?
                        What in 9/11 are you talking about, Snap?
                        • andyhundleyA
                          andyhundleyA
                          andyhundley
                          Jet fuel cant melt sound deadening. #neverforget
                            If removing sound deadening from your E30 causes your skin to fall off
                            youuuuu might be an aircraft.
                              I have a green car.
                              • johnprusinskiJ
                                johnprusinskiJ
                                johnprusinski
                                Ha-ha I like where this is going.
                                • johnprusinskiJ
                                  johnprusinskiJ
                                  johnprusinski
                                  Time for an update. I short of maxed my credit card out to buy a perts to rebuild the head on the black e30 and a cage for the v8 swap. The cage has a pretty huge leed time so I probably won't see that for a few months. I did however get my garagistic brake booster delete bracket. I won't go into details about the scrap they sent me. I also bought my pedals and masters. On February 19th I'll be buying coilovers. I also mounted my resivoirs for the pedals.
                                    What cam in the m20?
                                    • johnprusinskiJ
                                      johnprusinskiJ
                                      johnprusinski
                                      I bought a 284 degree cam.
                                      • CMartC
                                        CMartC
                                        CMart
                                        Interesting reservoir placement. Any reason they aren't in the bay?
                                        Excursion 7.3
                                        E30 LS1
                                          Keep an eye on the level as you drive maybe?
                                          Would a place let you pass tech with stuff in the cab like that John?
