  4. V8 Swapped E30
V8 Swapped E30
107 Posts 18 Posters 2.3k Views 2 Watching
  • johnprusinskiJ
    johnprusinskiJ
    johnprusinski
    I try to keep my build threads current, but I fail too hard at it. The only way I keep up is with Instagram. My next post with pictures will probably be in 3 months hahaha.
      Thanks for the summary! Paint looks great. This is why I wanna tear down on of the cars to its bones so I can learn how to do all this myself.
      It will be fun having two racecars when this is done ;)
      • johnprusinskiJ
        johnprusinskiJ
        johnprusinski
        I've done most of the body work with at least two to three beers in me to stay focused otherwise I wouldn't of a been able to do the body work. a lot of this stuff is tedious work, but its a great learning experience.
          This is awesome!
          • CMartC
            CMartC
            CMart
            At this rate it will be running before mine. Nice work.
            Excursion 7.3
            E30 LS1
            • johnprusinskiJ
              johnprusinskiJ
              johnprusinski
              its going to be a while before I get this thing running and driving. I still have to find a trans and buy the cage for the car. after that I need to figure out a dash, plus a whole interior. I want to hopefully start it and figure out the bay before I paint it. I also have to reinforce the rear end so I don't rip out my diff. I still have a lot, but hopefully I can get it close to finished next year.
              • CMartC
                CMartC
                CMart
                Nice. I'm doing a BMW V8 swap so not entirely the same, but if you have any questions or need a hand with anything shoot me a message. I'm over in Milwaukee.
                Edit - I just sold a 102MM Fast intake/ported TB, but still have some ls6 injections/fuel rail if you are interested.
                Excursion 7.3
                E30 LS1
                • johnprusinskiJ
                  johnprusinskiJ
                  johnprusinski
                  Im going to go with an ls3 intake with rails and injectors. Surprisingly the swap is very straight forward, its just affording a trans and wiring that's the only thing that's presenting a problem, but its not too big of a problem.
                  I took off the intake and wiring harness tonight. I want to take it out to get some work done soon to make it quick and reliable.
                  • johnprusinskiJ
                    johnprusinskiJ
                    johnprusinski
                    I took the time to try and fit the 6.0 in the car the other day. I day to pound out the trans tunnel with a hammer. the combination of beers and a hammer caused my trans tunnel to split and create a hole. I will fix that once I get more gas for the welder. right now it works as of right now, the motor fits in the car.
                    • johnprusinskiJ
                      johnprusinskiJ
                      johnprusinski
                      well after a few months of dumping all my money into my VW and other E30, I didn't get anything done on the V8 swap. I tore it down and decided what im going to do for power. I cleaned it up, painted and installed the oil pan. I also ordered a couple gaskets and sensors  that I broke along the way.im also starting to buy the accessories for the front.
                      im switching to LS1 accessories so i started by buying a LS1 crank pulley.
                      here is a basic idea of what the motor looks like now. i have the motor mounts back on it now.
                      i ordered a pedal assembly for the car so when that gets here i can start running lines.
                        Is that oil pan made for e30 purposes or just generic ls swap into anything purposes
                          Kind of reminds me of a Paul Poore SE30 pan
                          http://www.r3vlimited.com/board/showthread.php?t=368336
                          • CMartC
                            CMartC
                            CMart
                            Nice progress. I picked up an Cheby V8 E30 recently. I'd love to check this out some time
                            Excursion 7.3
                            E30 LS1
                            • johnprusinskiJ
                              johnprusinskiJ
                              johnprusinski
                              The oil pan is specifically built for LS bassed e30 swaps. I am currently prepping the cab for the cage by getting all of the tar out, which is not fun.
                                Dry ice is your friend.
                                • johnprusinskiJ
                                  johnprusinskiJ
                                  johnprusinski
                                  I learned that the hard way. It wasn't hard to get the sound deadning out, it was the residue. I used aircraft remover and it worked great, but I should've used dry ice.
                                    why did you remove an aircraft from your car?
                                      What in 9/11 are you talking about, Snap?
                                      • andyhundleyA
                                        andyhundleyA
                                        andyhundley
                                        Jet fuel cant melt sound deadening. #neverforget
                                          If removing sound deadening from your E30 causes your skin to fall off
                                          youuuuu might be an aircraft.
