  4. E21 project thread
E21 project thread
      After some setbacks Brian (Snap) and I got the car idling better with the megasquirt tune last week. Wasn't able to work on it all week, so today I fixed some minor leaks with sealant and am letting those dry over night. Tomorrow will hopefully be the day I take it for a test run when I get back from Woodstock, IL motorcycle swap meet. Let VEAL on tunerstudio do its thing and see what happens.
        I was talking to Snap the other day and he said you possibly have a bent valve. Is this true?
          I did a compression test today and compression on all cylinders checked out fine. Looks like all is good. My spark plug gap was really high tho, so I regapped them lower and seems to idle a lot smoother as well.
            He did the compression check and all is well, so the wadded up paper towel becoming jammed in a closing valve has been dismissed as a theory. What he DIDNT mention is that he had his plugs gapped such that you could fly the friggin space shuttle through them
              You troll, i was working on posting but you beat me to the punch. Im not deleting my post, though i may delete yours
                typical moderator, always making themselves look good and deleting others :P
                  This car drove.
                    And did a burnout right?
                      Yep,  burned out the remaining shop towels in the engine.
                        This car drove.
                        For a whole 30 feet!
                          driving is driving, whether an inch or a mile.
                              From last 30 foot drive, I heard a grinding/thumping from the rear which made me stop. This morning I raised the rear and noticed the driveshaft was rubbing on the exhaust. I got 2 new rubber muffler hangers and that fixed the issue. I then noticed a small oil leak. During my investigating I have a hunch it is coming from the thermostat on the oil filter housing. Hard to tell tho from the clean oil and whatnot.
                              I just drove it around the block for the first time and it was interesting. Lol. Figuring out Megasquirt as I go is probably going to take some time.
                              I also think there might be an exhaust leak at the turbo. Nows the time to get all the kinks out I guess.
                                I had a steady drip from the oil cooler thermostat on my m20, it got to the point of a drip every couple seconds when the engine was running.  I replaced the o ring (which comes with a new retaining ring and metal cap??) and all was well.  The old o ring crumbled into pieces when I removed it.
                                  Not sure if mine has/had an oring since its basically just a sandwich plate with a built in thermostat. I know it has a c-clip that holds it all inside the housing tho.
                                    So when is this thing getting the kit thrown on and a video of some sideways action?
                                      In due time sir, in due time.
                                        Is it like this?
                                        If so this is what is inside the end (also a spring and thermostat piece.)  Only one set, this is the old vs new when I replaced the o-ring.
                                          I don't have an m20 in my e21. I am using a purolater thermostatic sandwich adapter on my m10 filter housing.
