  4. E21 project thread
E21 project thread
    Well got it all together and she fired right up! Idles super rich to the point of almost dying without having an IAC hooked up tho. Hhmmm
      Congrats=)
          After some setbacks Brian (Snap) and I got the car idling better with the megasquirt tune last week. Wasn't able to work on it all week, so today I fixed some minor leaks with sealant and am letting those dry over night. Tomorrow will hopefully be the day I take it for a test run when I get back from Woodstock, IL motorcycle swap meet. Let VEAL on tunerstudio do its thing and see what happens.
            I was talking to Snap the other day and he said you possibly have a bent valve. Is this true?
              I did a compression test today and compression on all cylinders checked out fine. Looks like all is good. My spark plug gap was really high tho, so I regapped them lower and seems to idle a lot smoother as well.
                He did the compression check and all is well, so the wadded up paper towel becoming jammed in a closing valve has been dismissed as a theory. What he DIDNT mention is that he had his plugs gapped such that you could fly the friggin space shuttle through them
                  You troll, i was working on posting but you beat me to the punch. Im not deleting my post, though i may delete yours
                    typical moderator, always making themselves look good and deleting others :P
                      This car drove.
                        And did a burnout right?
                          Yep,  burned out the remaining shop towels in the engine.
                            This car drove.
                            For a whole 30 feet!
                              driving is driving, whether an inch or a mile.
                                  From last 30 foot drive, I heard a grinding/thumping from the rear which made me stop. This morning I raised the rear and noticed the driveshaft was rubbing on the exhaust. I got 2 new rubber muffler hangers and that fixed the issue. I then noticed a small oil leak. During my investigating I have a hunch it is coming from the thermostat on the oil filter housing. Hard to tell tho from the clean oil and whatnot.
                                  I just drove it around the block for the first time and it was interesting. Lol. Figuring out Megasquirt as I go is probably going to take some time.
                                  I also think there might be an exhaust leak at the turbo. Nows the time to get all the kinks out I guess.
                                    I had a steady drip from the oil cooler thermostat on my m20, it got to the point of a drip every couple seconds when the engine was running.  I replaced the o ring (which comes with a new retaining ring and metal cap??) and all was well.  The old o ring crumbled into pieces when I removed it.
                                      Not sure if mine has/had an oring since its basically just a sandwich plate with a built in thermostat. I know it has a c-clip that holds it all inside the housing tho.
                                        So when is this thing getting the kit thrown on and a video of some sideways action?
                                          In due time sir, in due time.
