  4. E21 project thread
E21 project thread
233 Posts 19 Posters 0 Views 1 Watching
    typical moderator, always making themselves look good and deleting others :P
      This car drove.
        And did a burnout right?
          Yep,  burned out the remaining shop towels in the engine.
            This car drove.
            For a whole 30 feet!
              driving is driving, whether an inch or a mile.
                  From last 30 foot drive, I heard a grinding/thumping from the rear which made me stop. This morning I raised the rear and noticed the driveshaft was rubbing on the exhaust. I got 2 new rubber muffler hangers and that fixed the issue. I then noticed a small oil leak. During my investigating I have a hunch it is coming from the thermostat on the oil filter housing. Hard to tell tho from the clean oil and whatnot.
                  I just drove it around the block for the first time and it was interesting. Lol. Figuring out Megasquirt as I go is probably going to take some time.
                  I also think there might be an exhaust leak at the turbo. Nows the time to get all the kinks out I guess.
                    I had a steady drip from the oil cooler thermostat on my m20, it got to the point of a drip every couple seconds when the engine was running.  I replaced the o ring (which comes with a new retaining ring and metal cap??) and all was well.  The old o ring crumbled into pieces when I removed it.
                      Not sure if mine has/had an oring since its basically just a sandwich plate with a built in thermostat. I know it has a c-clip that holds it all inside the housing tho.
                        So when is this thing getting the kit thrown on and a video of some sideways action?
                          In due time sir, in due time.
                            Is it like this?
                            If so this is what is inside the end (also a spring and thermostat piece.)  Only one set, this is the old vs new when I replaced the o-ring.
                              I don't have an m20 in my e21. I am using a purolater thermostatic sandwich adapter on my m10 filter housing.
                                I didn't know if they used a similar setup on the m10.  I didn't realize yours was aftermarket, I have considered using an adapter to do a remote mount filter on some cars with poor filter placement to make oil changes easier.  Would you recommend the Purolator?  I use their synthetic line of spin on filters for my non BMWs.
                                  Purolater and mahle are OEM bmw filter suppliers
                                    Yeah I would recommend Purolator. That is my go to filer for my car, but most the time no one has it in stock so I end up having to get something different.
                                    I have been tuning and tuning with Brian (Snap) and we are kind of stumped. It is running almost as if a spark plug is intermittent or wire is bad, but I just replaced plugs and wires. We are aiming towards the coil not producing a hot enough spark and maybe even the EDIS module not being grounded properly due to it sitting on a painted surface. I will be replacing the coil today and possibly grinding the paint away from under the module. Hope this works.
                                      Its just like how milwaukeeandy's car was with the wrong coil dwell settings. Its as if the spark is too weak or the atomization is poor
                                        The new coil and edis module grounding didn't change it a whole lot. It sputtered a tiny bit less often, but still sputters nonetheless. Next up, bad batch of fuel maybe?
                                          Now I'm ready for some serious tunage!
