E21 project thread
Finally after what feels like a bajillion times trying to get this fuel rail to stop leaking its actually stopped leaking. The metal that these rails are made out of just do not weld well. So I ended up cutting off fpr bracket and cup, drilling/tapping a large nut and welding that to the rail. Then I covered the entire area with 2 layers of jb weld and 2 coats of KBS rust seal paint.
Leaking
Fixed
While all that was happening, I kept my sanity by doing other things such as...
Painting some emblems to match
And replacing US seatbelt/o2 sensor light with a blank piece
Now to mount the fpr, run longer hoses, put things back together and start tuning megasquirt! Calling on Snap!
After work I started on getting things back together. I put some fuel sealant on the fuel rail fitting. That needs 24 hours to dry before allowing fuel through it, so I starting on the fpr mounts.
I took the left over aluminum stock from the oil catch can mount I made, cut and bent it to shape, drilled some holes and done! Sprayed it all black and waiting for it to dry. Tomorrow I will run new hoses and put more back together.
This is awesome!!!
Almost there bassface!!!
Well got it all together and she fired right up! Idles super rich to the point of almost dying without having an IAC hooked up tho. Hhmmm
After some setbacks Brian (Snap) and I got the car idling better with the megasquirt tune last week. Wasn't able to work on it all week, so today I fixed some minor leaks with sealant and am letting those dry over night. Tomorrow will hopefully be the day I take it for a test run when I get back from Woodstock, IL motorcycle swap meet. Let VEAL on tunerstudio do its thing and see what happens.
I did a compression test today and compression on all cylinders checked out fine. Looks like all is good. My spark plug gap was really high tho, so I regapped them lower and seems to idle a lot smoother as well.
typical moderator, always making themselves look good and deleting others
This car drove.
For a whole 30 feet!
From last 30 foot drive, I heard a grinding/thumping from the rear which made me stop. This morning I raised the rear and noticed the driveshaft was rubbing on the exhaust. I got 2 new rubber muffler hangers and that fixed the issue. I then noticed a small oil leak. During my investigating I have a hunch it is coming from the thermostat on the oil filter housing. Hard to tell tho from the clean oil and whatnot.
I just drove it around the block for the first time and it was interesting. Lol. Figuring out Megasquirt as I go is probably going to take some time.
I also think there might be an exhaust leak at the turbo. Nows the time to get all the kinks out I guess.
