  4. E21 project thread
E21 project thread
    I was talking to Snap the other day and he said you possibly have a bent valve. Is this true?
      I did a compression test today and compression on all cylinders checked out fine. Looks like all is good. My spark plug gap was really high tho, so I regapped them lower and seems to idle a lot smoother as well.
        He did the compression check and all is well, so the wadded up paper towel becoming jammed in a closing valve has been dismissed as a theory. What he DIDNT mention is that he had his plugs gapped such that you could fly the friggin space shuttle through them
          You troll, i was working on posting but you beat me to the punch. Im not deleting my post, though i may delete yours
            typical moderator, always making themselves look good and deleting others :P
              This car drove.
                And did a burnout right?
                  Yep,  burned out the remaining shop towels in the engine.
                    This car drove.
                    For a whole 30 feet!
                      driving is driving, whether an inch or a mile.
                          From last 30 foot drive, I heard a grinding/thumping from the rear which made me stop. This morning I raised the rear and noticed the driveshaft was rubbing on the exhaust. I got 2 new rubber muffler hangers and that fixed the issue. I then noticed a small oil leak. During my investigating I have a hunch it is coming from the thermostat on the oil filter housing. Hard to tell tho from the clean oil and whatnot.
                          I just drove it around the block for the first time and it was interesting. Lol. Figuring out Megasquirt as I go is probably going to take some time.
                          I also think there might be an exhaust leak at the turbo. Nows the time to get all the kinks out I guess.
                            I had a steady drip from the oil cooler thermostat on my m20, it got to the point of a drip every couple seconds when the engine was running.  I replaced the o ring (which comes with a new retaining ring and metal cap??) and all was well.  The old o ring crumbled into pieces when I removed it.
                              Not sure if mine has/had an oring since its basically just a sandwich plate with a built in thermostat. I know it has a c-clip that holds it all inside the housing tho.
                                So when is this thing getting the kit thrown on and a video of some sideways action?
                                  In due time sir, in due time.
                                    Is it like this?
                                    If so this is what is inside the end (also a spring and thermostat piece.)  Only one set, this is the old vs new when I replaced the o-ring.
                                      I don't have an m20 in my e21. I am using a purolater thermostatic sandwich adapter on my m10 filter housing.
                                        I didn't know if they used a similar setup on the m10.  I didn't realize yours was aftermarket, I have considered using an adapter to do a remote mount filter on some cars with poor filter placement to make oil changes easier.  Would you recommend the Purolator?  I use their synthetic line of spin on filters for my non BMWs.
                                          Purolater and mahle are OEM bmw filter suppliers
