  4. E21 project thread
E21 project thread
233 Posts 19 Posters 0 Views 1 Watching
    It all falls in line, huh? :P
      So I got the fuel rail dye checked and rewelded and still has a leak. This obviously means its something else. After thinking and thinking some more, I realized that the stock cup that the FPR o-ring goes into was tapered, just like the injector cups. When I modified the rail I had to make a new cup and weld it on. Doing so, the new cup is not tapered and I am assuming that the o-ring is not sealing properly due to this.
      What I am thinking now is to cut off the FPR bracket and cup from the rail, weld on a nipple, then its just running a fuel hose to an aftermarket FPR. I didn't want to go this route before since I hate the look of those stupid adjustable FPR's with the gauge on it and junk. I then thought, maybe it won't be so bad. I can have the gauge on the FPR to dial in the pressure (3.5bar or roughly 50psi), unscrew the gauge from the FPR and screw in a plug. This way it wont look as stupid. Seems like the easiest route to take and less chance of leaking.
        You can mount it in an inconspicuous place at least, it's not like you have to access the fpr that often.
          Finally after what feels like a bajillion times trying to get this fuel rail to stop leaking its actually stopped leaking. The metal that these rails are made out of just do not weld well. So I ended up cutting off fpr bracket and cup, drilling/tapping a large nut and welding that to the rail. Then I covered the entire area with 2 layers of jb weld and 2 coats of KBS rust seal paint.
          Leaking
          Fixed
          While all that was happening, I kept my sanity by doing other things such as...
          Painting some emblems to match
          And replacing US seatbelt/o2 sensor light with a blank piece
          Now to mount the fpr, run longer hoses, put things back together and start tuning megasquirt! Calling on Snap! :lol:
            After work I started on getting things back together. I put some fuel sealant on the fuel rail fitting. That needs 24 hours to dry before allowing fuel through it, so I starting on the fpr mounts.
            I took the left over aluminum stock from the oil catch can mount I made, cut and bent it to shape, drilled some holes and done! Sprayed it all black and waiting for it to dry. Tomorrow I will run new hoses and put more back together.
              This is awesome!!!
                Almost there bassface!!!
                  Well got it all together and she fired right up! Idles super rich to the point of almost dying without having an IAC hooked up tho. Hhmmm
                    Congrats=)
                        After some setbacks Brian (Snap) and I got the car idling better with the megasquirt tune last week. Wasn't able to work on it all week, so today I fixed some minor leaks with sealant and am letting those dry over night. Tomorrow will hopefully be the day I take it for a test run when I get back from Woodstock, IL motorcycle swap meet. Let VEAL on tunerstudio do its thing and see what happens.
                          I was talking to Snap the other day and he said you possibly have a bent valve. Is this true?
                            I did a compression test today and compression on all cylinders checked out fine. Looks like all is good. My spark plug gap was really high tho, so I regapped them lower and seems to idle a lot smoother as well.
                              He did the compression check and all is well, so the wadded up paper towel becoming jammed in a closing valve has been dismissed as a theory. What he DIDNT mention is that he had his plugs gapped such that you could fly the friggin space shuttle through them
                                You troll, i was working on posting but you beat me to the punch. Im not deleting my post, though i may delete yours
                                  typical moderator, always making themselves look good and deleting others :P
                                    This car drove.
                                      And did a burnout right?
                                        Yep,  burned out the remaining shop towels in the engine.
                                          This car drove.
                                          For a whole 30 feet!
