  4. E30 M52
E30 M52
    +1 for using a time-serts, a much better option IMO. I would think you of all people would hate to do something a second or third time.
    I have 3 kids,  what are you trying to say here?!?!
    Gosh dang you guys and your Timesert recommendations after I have already committed to using a Helicoil
      LOL.  Time -to - insert, bad pun here.
      • JeffJ
        JeffJ
        Jeff
        +1 to Helicoil
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
        • JeffJ
          JeffJ
          Jeff
          Really I have used 1000's of these without issues on low torque applications. Just make sure the STI tapped hole is clear of chips before installing.
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            Jeff got my back
            • JeffJ
              JeffJ
              Jeff
              [emoji207]
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
                  As soon as I realized I had a problem the devil whispered that in my ear. Alas, I did not yield to temptation.
                  The devil is janky.
                    Oil pan off, oil pump shaft/rotor removed, e39 oil pan thrown in garbage, worthless stock e34 oil pan baffle removed and thrown in garbage, arrangements made to drop off pan and Achillies Motorsport baffle off with welderdude tomorrow.
                    Stock oil pump shaft will be pressed out tomorrow at work and upgraded one installed. Stock oil pump sprocket, nut and shaft will be thrown in the garbage tomorrow
                      Old oil pump shaft pressed out and thrown in the garbage.
                      New "upgraded" oil pump shaft pressed in. In the second image you can see why the new one is an upgrade as It gets rid of the undercut required to make the splines.
                        Not sure if this is a test to see if we are actually paying attention, or you really don't like following the rules.
                          To be fair, the method shown in the instructions is a pretty inaccurate way to use calipers.
                            Measuring off the back face of the rotor made it easier for me to be square and consistent in measuring. +10 internets for catching that though
                            • JeffJ
                              JeffJ
                              Jeff
                              I'm pretty sure that that is about as accurate as a tape measure.
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                                I installed my 2 helicoils. The cam trays are no fun to install. I am using a folded over strip of tape to keep the lifters from falling out but it looks like I will need to resort to using magnets.
                                I have so much sweat
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  Assembly lube fixes the issue of them falling out.
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                    More stripped threads happening on the exhaust cam studs
                                    Im using a small in-lb beam torque wrench but am going to buy something more expensive just because this is getting ridiculous.
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      Jesus
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                        The M20 would have never done this to me.
                                        Partly because it doesnt have bearing caps
