  4. E30 M52
E30 M52
    Odd that the head-side went. You'd think the stud would be bottomed out and the nut wouldn't turn it anymore.
    But as you said. 100000 times better than a cam
    • JeffJ
      JeffJ
      Jeff
      1000x better than breaking a camshaft though. I'll take it.
      But see now your doubling your chances at breaking it so that would be -1000x. We both know that will just cancel it self out now and create the crazy looking number "0"
      Practice makes perfect?
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
      • The Full BananaT
        The Full BananaT
        The Full Banana
        Helicoils are garbage. Get some keenserts from McMaster!
        says the guy who had to use them too many times on his all aluminum engine. 😦
          Times-sert is another option.
          Don't have any experience with them, but my boss thinks they are great. Do have experience with heli-coils, mostly trying to fix ones that someone else has installed and have now failed. Not fun.
            Being a low torque application I will stick with heli-coils. If it were head bolt threads in an aluminum block id definitely consider the timesert. Thanks for the mentions though
            • The Full BananaT
              The Full BananaT
              The Full Banana
              Good luck. If the helicoils give you trouble, keenserts (or timeserts) will be there for you. I had about 50% success rate with helicoils in the same application (aluminum head, low torque fasteners to secure the cams) before being shown the light by a friend.
                Coolant pipe adapter installed. I went with the overpriced one from Turner rather than the overpriced one from Achillies or making my own. I like the fact that this kit comes with a popsicle stick and DOUBLE/BUBBLE brand 2 part epoxy.
                  +1 for using a time-serts, a much better option IMO. I would think you of all people would hate to do something a second or third time.
                    I have 3 kids,  what are you trying to say here?!?!
                    Gosh dang you guys and your Timesert recommendations after I have already committed to using a Helicoil
                      LOL.  Time -to - insert, bad pun here.
                      • JeffJ
                        JeffJ
                        Jeff
                        +1 to Helicoil
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                        • JeffJ
                          JeffJ
                          Jeff
                          Really I have used 1000's of these without issues on low torque applications. Just make sure the STI tapped hole is clear of chips before installing.
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                            Jeff got my back
                            • JeffJ
                              JeffJ
                              Jeff
                              [emoji207]
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                                  As soon as I realized I had a problem the devil whispered that in my ear. Alas, I did not yield to temptation.
                                  The devil is janky.
                                    Oil pan off, oil pump shaft/rotor removed, e39 oil pan thrown in garbage, worthless stock e34 oil pan baffle removed and thrown in garbage, arrangements made to drop off pan and Achillies Motorsport baffle off with welderdude tomorrow.
                                    Stock oil pump shaft will be pressed out tomorrow at work and upgraded one installed. Stock oil pump sprocket, nut and shaft will be thrown in the garbage tomorrow
                                      Old oil pump shaft pressed out and thrown in the garbage.
                                      New "upgraded" oil pump shaft pressed in. In the second image you can see why the new one is an upgrade as It gets rid of the undercut required to make the splines.
                                        Not sure if this is a test to see if we are actually paying attention, or you really don't like following the rules.
                                          To be fair, the method shown in the instructions is a pretty inaccurate way to use calipers.
