E30 M52
As soon as I realized I had a problem the devil whispered that in my ear. Alas, I did not yield to temptation.
The devil is janky.
Oil pan off, oil pump shaft/rotor removed, e39 oil pan thrown in garbage, worthless stock e34 oil pan baffle removed and thrown in garbage, arrangements made to drop off pan and Achillies Motorsport baffle off with welderdude tomorrow.
Stock oil pump shaft will be pressed out tomorrow at work and upgraded one installed. Stock oil pump sprocket, nut and shaft will be thrown in the garbage tomorrow
Not sure if this is a test to see if we are actually paying attention, or you really don't like following the rules.
I'm pretty sure that that is about as accurate as a tape measure.
I installed my 2 helicoils. The cam trays are no fun to install. I am using a folded over strip of tape to keep the lifters from falling out but it looks like I will need to resort to using magnets.
I have so much sweat
Assembly lube fixes the issue of them falling out.
Seeing this makes me feel quite a bit better actually.
I got the intake cam installed and torqu... no I didnt. The last 2 stripped.
Im even using a brand new torque wrench with a certificate of calibration and everything.
Stupid 24V
Update: fixed 1 of the 3 remaining stripped holes. Tap fell and rolled somewhere. 10 minutes of sweaty searching and I quit. I'll just buy a new one and find the old one right after I start using it.
Let me also tell you of the struggle of getting a straight drill/tap with the head on the engine hanging from an engine hoist (i cannot rest it on something now because the pan is off)
This is a common occurrence on the Toyota 3VZE which is also a shitty engine
