  4. E30 M52
E30 M52
    Old oil pump shaft pressed out and thrown in the garbage.
    New "upgraded" oil pump shaft pressed in. In the second image you can see why the new one is an upgrade as It gets rid of the undercut required to make the splines.
      Not sure if this is a test to see if we are actually paying attention, or you really don't like following the rules.
        To be fair, the method shown in the instructions is a pretty inaccurate way to use calipers.
          Measuring off the back face of the rotor made it easier for me to be square and consistent in measuring. +10 internets for catching that though
          • JeffJ
            JeffJ
            Jeff
            I'm pretty sure that that is about as accurate as a tape measure.
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
              I installed my 2 helicoils. The cam trays are no fun to install. I am using a folded over strip of tape to keep the lifters from falling out but it looks like I will need to resort to using magnets.
              I have so much sweat
              • JeffJ
                JeffJ
                Jeff
                Assembly lube fixes the issue of them falling out.
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                  More stripped threads happening on the exhaust cam studs
                  Im using a small in-lb beam torque wrench but am going to buy something more expensive just because this is getting ridiculous.
                  • JeffJ
                    JeffJ
                    Jeff
                    Jesus
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      The M20 would have never done this to me.
                      Partly because it doesnt have bearing caps
                          14590867121628019839308150775123044262
                            Seeing this makes me feel quite a bit better actually.
                              That is: AMAZING.
                                I got the intake cam installed and torqu... no I didnt. The last 2 stripped.
                                Im even using a brand new torque wrench with a certificate of calibration and everything.
                                Stupid 24V
                                Update: fixed 1 of the 3 remaining stripped holes. Tap fell and rolled somewhere. 10 minutes of sweaty searching and I quit. I'll just buy a new one and find the old one right after I start using it.
                                Let me also tell you of the struggle of getting a straight drill/tap with the head on the engine hanging from an engine hoist (i cannot rest it on something now because the pan is off)
                                This is a common occurrence on the Toyota 3VZE which is also a shitty engine
                                  run it.
                                    This is my lifter bucket keeper-upper so the lifters dont fall out when removing/installing the cam trays.
                                    Steel rod with some magnets
                                    I was going to assemble the oil pump with the E34 pickup tube but noticed a knick in the pump outer ring. 7cef1722c82b0915ffa066a43c5373be.jpg
                                    (Assembled view so you can see what part I am talking about)
                                    This part isnt under too much stress but it gets loaded cyclically and its a perfect storm for a crack to form from fatigue+heat. If the ring opens up at all it will jam/sieze
                                    I am ordering a new one and will replace the pressure relief valve components while im at it. I wasnt planning on it but its a Wednesday and I had KFC for dinner so I guess I will
                                    This is the bracket for the rear-sump pickup tube. It gets bent/broken off for fitment of the front sump pan.
                                    My progress is at a crossroads until parts arrive and there isnt too much I can do to keep moving forward so I think I will use the time to modify the shift linkage and shift carrier so i can drop them off with Mr. Welderdude.
                                    I picked up the oil pan from him monday
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      Nice update! I love the idea with the magnets holding the lifters.
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                        Chugga chugga chugga. You going to be driving this to the fall meet?
                                        • The Full BananaT
                                          The Full BananaT
                                          The Full Banana
                                          Are we there yet?
