E30 M52
+1 for using a time-serts, a much better option IMO. I would think you of all people would hate to do something a second or third time.
I have 3 kids, what are you trying to say here?!?!
Gosh dang you guys and your Timesert recommendations after I have already committed to using a Helicoil
LOL. Time -to - insert, bad pun here.
As soon as I realized I had a problem the devil whispered that in my ear. Alas, I did not yield to temptation.
The devil is janky.
Oil pan off, oil pump shaft/rotor removed, e39 oil pan thrown in garbage, worthless stock e34 oil pan baffle removed and thrown in garbage, arrangements made to drop off pan and Achillies Motorsport baffle off with welderdude tomorrow.
Stock oil pump shaft will be pressed out tomorrow at work and upgraded one installed. Stock oil pump sprocket, nut and shaft will be thrown in the garbage tomorrow
Not sure if this is a test to see if we are actually paying attention, or you really don't like following the rules.
I'm pretty sure that that is about as accurate as a tape measure.
I installed my 2 helicoils. The cam trays are no fun to install. I am using a folded over strip of tape to keep the lifters from falling out but it looks like I will need to resort to using magnets.
I have so much sweat
Assembly lube fixes the issue of them falling out.
