  4. E30 M52
E30 M52
  • JeffJ
    JeffJ
    Jeff
    1000x better than breaking a camshaft though. I'll take it.
    But see now your doubling your chances at breaking it so that would be -1000x. We both know that will just cancel it self out now and create the crazy looking number "0"
    Practice makes perfect?
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
    • The Full BananaT
      The Full BananaT
      The Full Banana
      Helicoils are garbage. Get some keenserts from McMaster!
      says the guy who had to use them too many times on his all aluminum engine. 😦
        Times-sert is another option.
        Don't have any experience with them, but my boss thinks they are great. Do have experience with heli-coils, mostly trying to fix ones that someone else has installed and have now failed. Not fun.
          Being a low torque application I will stick with heli-coils. If it were head bolt threads in an aluminum block id definitely consider the timesert. Thanks for the mentions though
          • The Full BananaT
            The Full BananaT
            The Full Banana
            Good luck. If the helicoils give you trouble, keenserts (or timeserts) will be there for you. I had about 50% success rate with helicoils in the same application (aluminum head, low torque fasteners to secure the cams) before being shown the light by a friend.
              Coolant pipe adapter installed. I went with the overpriced one from Turner rather than the overpriced one from Achillies or making my own. I like the fact that this kit comes with a popsicle stick and DOUBLE/BUBBLE brand 2 part epoxy.
                +1 for using a time-serts, a much better option IMO. I would think you of all people would hate to do something a second or third time.
                  I have 3 kids,  what are you trying to say here?!?!
                  Gosh dang you guys and your Timesert recommendations after I have already committed to using a Helicoil
                    LOL.  Time -to - insert, bad pun here.
                    • JeffJ
                      JeffJ
                      Jeff
                      +1 to Helicoil
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                      • JeffJ
                        JeffJ
                        Jeff
                        Really I have used 1000's of these without issues on low torque applications. Just make sure the STI tapped hole is clear of chips before installing.
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          Jeff got my back
                          • JeffJ
                            JeffJ
                            Jeff
                            [emoji207]
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                                As soon as I realized I had a problem the devil whispered that in my ear. Alas, I did not yield to temptation.
                                The devil is janky.
                                  Oil pan off, oil pump shaft/rotor removed, e39 oil pan thrown in garbage, worthless stock e34 oil pan baffle removed and thrown in garbage, arrangements made to drop off pan and Achillies Motorsport baffle off with welderdude tomorrow.
                                  Stock oil pump shaft will be pressed out tomorrow at work and upgraded one installed. Stock oil pump sprocket, nut and shaft will be thrown in the garbage tomorrow
                                    Old oil pump shaft pressed out and thrown in the garbage.
                                    New "upgraded" oil pump shaft pressed in. In the second image you can see why the new one is an upgrade as It gets rid of the undercut required to make the splines.
                                      Not sure if this is a test to see if we are actually paying attention, or you really don't like following the rules.
                                        To be fair, the method shown in the instructions is a pretty inaccurate way to use calipers.
                                          Measuring off the back face of the rotor made it easier for me to be square and consistent in measuring. +10 internets for catching that though
