  4. V8 Swapped E30
V8 Swapped E30
107 Posts 18 Posters 2.3k Views 2 Watching
  • johnprusinskiJ
    johnprusinskiJ
    johnprusinski
    I learned that the hard way. It wasn't hard to get the sound deadning out, it was the residue. I used aircraft remover and it worked great, but I should've used dry ice.
      why did you remove an aircraft from your car?
        What in 9/11 are you talking about, Snap?
        • andyhundleyA
          andyhundleyA
          andyhundley
          Jet fuel cant melt sound deadening. #neverforget
            If removing sound deadening from your E30 causes your skin to fall off
            youuuuu might be an aircraft.
              I have a green car.
              • johnprusinskiJ
                johnprusinskiJ
                johnprusinski
                Ha-ha I like where this is going.
                • johnprusinskiJ
                  johnprusinskiJ
                  johnprusinski
                  Time for an update. I short of maxed my credit card out to buy a perts to rebuild the head on the black e30 and a cage for the v8 swap. The cage has a pretty huge leed time so I probably won't see that for a few months. I did however get my garagistic brake booster delete bracket. I won't go into details about the scrap they sent me. I also bought my pedals and masters. On February 19th I'll be buying coilovers. I also mounted my resivoirs for the pedals.
                    What cam in the m20?
                    • johnprusinskiJ
                      johnprusinskiJ
                      johnprusinski
                      I bought a 284 degree cam.
                      • CMartC
                        CMartC
                        CMart
                        Interesting reservoir placement. Any reason they aren't in the bay?
                        Excursion 7.3
                        E30 LS1
                          Keep an eye on the level as you drive maybe?
                          Would a place let you pass tech with stuff in the cab like that John?
                            A guy on BF who has a track e21 has his reservoirs in the cabin as well. So I assume it doesn't matter
                              I've seen them inside plenty of times but never on the outside of the dash. I've only seen them mounted under the dash centrally or right above the pedal box
                                Might depend on which orgs you run with. Usually tech rules for racing are stricter than DE, and/or more strictly enforced.
                                There is often the blanket prep rule that if the rules don't say you can do X then you can't do X. The other broad rule that might apply is that hoses in the cabin carrying hot or flammable liquids have to be metal or reinforced (e.g., braided steel for your lines).
                                • johnprusinskiJ
                                  johnprusinskiJ
                                  johnprusinski
                                  I will be OK with mounting everything inside the cab. I plan to switch to steal braided lines, but I'm using the rubber lines for mock up, because they came with the masters.
                                  • CMartC
                                    CMartC
                                    CMart
                                    Definitely unique.
                                    Mine are rubber lines as well. I didn't think it mattered all the much being before the high pressure.
                                    Excursion 7.3
                                    E30 LS1
                                    • johnprusinskiJ
                                      johnprusinskiJ
                                      johnprusinski
                                      I got some ABS plastic tonight and ended up making a plate and I mounted my resivoirs.
                                      • CMartC
                                        CMartC
                                        CMart
                                        Is your bay really that crowded?
                                        Excursion 7.3
                                        E30 LS1
                                        • CMartC
                                          CMartC
                                          CMart
                                          Same setup:
                                          Excursion 7.3
                                          E30 LS1
