  4. V8 Swapped E30
V8 Swapped E30
107 Posts 18 Posters 2.3k Views 2 Watching
  • CMartC
    CMartC
    CMart
    Interesting reservoir placement. Any reason they aren't in the bay?
    Excursion 7.3
    E30 LS1
      Keep an eye on the level as you drive maybe?
      Would a place let you pass tech with stuff in the cab like that John?
        A guy on BF who has a track e21 has his reservoirs in the cabin as well. So I assume it doesn't matter
          I've seen them inside plenty of times but never on the outside of the dash. I've only seen them mounted under the dash centrally or right above the pedal box
            Might depend on which orgs you run with. Usually tech rules for racing are stricter than DE, and/or more strictly enforced.
            There is often the blanket prep rule that if the rules don't say you can do X then you can't do X. The other broad rule that might apply is that hoses in the cabin carrying hot or flammable liquids have to be metal or reinforced (e.g., braided steel for your lines).
            • johnprusinskiJ
              johnprusinskiJ
              johnprusinski
              I will be OK with mounting everything inside the cab. I plan to switch to steal braided lines, but I'm using the rubber lines for mock up, because they came with the masters.
              • CMartC
                CMartC
                CMart
                Definitely unique.
                Mine are rubber lines as well. I didn't think it mattered all the much being before the high pressure.
                Excursion 7.3
                E30 LS1
                • johnprusinskiJ
                  johnprusinskiJ
                  johnprusinski
                  I got some ABS plastic tonight and ended up making a plate and I mounted my resivoirs.
                  • CMartC
                    CMartC
                    CMart
                    Is your bay really that crowded?
                    Excursion 7.3
                    E30 LS1
                    • CMartC
                      CMartC
                      CMart
                      Same setup:
                      Excursion 7.3
                      E30 LS1
                      • johnprusinskiJ
                        johnprusinskiJ
                        johnprusinski
                        I wont know for sure until I have everything mocked up in the bay. As of right now everything can be changed and Ill make the final decision once the motor is all done and in.
                          its like those 1900s race cars where you need a co-pilot to watch/fill the oil level because pistons had no rings and all the oil was dumped right out the exhaust.
                          • CMartC
                            CMartC
                            CMart
                            Are you deleting the heat/vents?
                            Excursion 7.3
                            E30 LS1
                            • johnprusinskiJ
                              johnprusinskiJ
                              johnprusinski
                              Yes, I'm deleting all of the heater vents. I'll be putting gauges in the middle vents and on the driver's side vent. The passenger side vent is just getting blocked off.
                              • CMartC
                                CMartC
                                CMart
                                That makes things easier. I was hoping you found a way to relocate the atmosphere controls. I would love to use that space for something better.
                                Excursion 7.3
                                E30 LS1
                                • johnprusinskiJ
                                  johnprusinskiJ
                                  johnprusinski
                                  I took everything out including the heatercore so no heat. I think it would be hard to move the climate controls.
                                  • johnprusinskiJ
                                    johnprusinskiJ
                                    johnprusinski
                                    I'm still making progress on the dash plates.
                                      Flame suit: [ON] OFF
                                      (R3v)
                                      • johnprusinskiJ
                                        johnprusinskiJ
                                        johnprusinski
                                        They tore me apart. I don't understand why? The pedals are designed to attach to the masters right above your feet. It's not illegal to have them in the cab either.
                                          They just figure you would want them out of sight and your current location would be better suited for switches of gages. For me it would seem better to try and mount them under the dash right above the pedals to have the shortest lines going down to the pedal. You dont need much room above them because you can fill them with fluid using a bottle pump=)
