  4. '88 E30
'88 E30
savebigmoney
    CMart said:
    well it happened, ordered about $1650 worth of crap tonight for it. (will get about $160 back in core)
    Still remaining to buy:
    coil overs
    brake pads & fluid (still on the fence about pads)
    front stainless brake lines
    Not sure if I asked/you answered, but any interest in my coilover setup or coilover/bbk setup
      wasnt m3 said:
      What did you buy?
      Inner/outer tierods
      Boots
      Clamps
      Lock plates
      Control arms
      Wheel bearings
      Wheel bearing circlips
      Axle lock plates
      Axle nuts
      Wheel bearings
      Brembo blanks
      Calipers
      Skid plate
      ST sways
      Akg sway bar mount reinforcement
      Dust shields
        coil overs
        I didn't even know you had stuff. Just bought brakes/calipers too.......
        • CMartC
          CMartC
          CMart
          I've got a stance coilover/camber plate setup already welded up ready to bolt on. I also have a RX7 BBK that I could include.
          Bad picture, but:
          12736060_10102633118162083_1163972206_n
          Excursion 7.3
          E30 LS1
            Do you know the spring rates?
            I probably won't need the brake stuff as I've already ordered brakes/calipers
              coil overs
              That's some serious cash coming from the guy who didn't want to buy a radiator fan relay. 😛 Keep up the good work!!
              • CMartC
                CMartC
                CMart
                I want to say 8k front 9k rear but would I've to confirm that.
                Excursion 7.3
                E30 LS1
                  Brake supplies are in! Just need to get some front stainless lines and pads/fluid
                    wheel bearings/lock rings, rack boots/clamps, rear sway bar mount reinforcements came today
                    getting closer
                      Got the new wheel bearings and hubs pressed into the trailing arms today.
                      Only things I'm waiting on is the skid plate & tierods (and the crap I haven't ordered yet)
                      Gonna hopefully convince myself to work on it tomorrow
                        This was more of a pain in the ass than I'd like to admit, especially by myself a584a19006dc4e29a38df37fc78704bb.jpg
                        Butttttt the rear sway bar is in. ST 19mm. Can't imagine doing that with all the subframe crap in the way
                          I can confirm the lack of joy that takes place during sway bar installs. The flatter cornering is all worth it
                            With the subframe in place installing the larger sway involves both wheels off and creative threading the bar in from the passenger side. It works but is a pain. Key is to figure out the proper orientation before you start threading it in. Much easier your way.
                              Rest of the parts have arrived.
                              24v skid plate from red46
                              Inner and outer e36 tierods
                              Driveshaft nuts
                              Spring pads
                              Still need to order
                              Suspension (coils?)
                              Brake pads
                              Front brake lines
                              And probably some misc stuff
                                sway bars suck third-ed and move to strike.
                                glad you got a skid plate, they are 100% necessary for these swaps.
                                  Only thing I'm nervous about is I have an aftermarket core support (my original one was kinda twisted and rusty) the aftermarket China ones work well enough, they are just quite thin and bendy. I think it should work because the red46 plate includes some hardware (drilling required) which includes a plate to sandwich the core support. Should be fine unless I go bounce off some rocks out in moab
                                    You could always cut the core support open and stick a piece of square tube in there.
                                    Wait, e30's aren't supposed to go to Moab? I better cancel my trip.....
                                      We will see if the square tube is needed. For my uses, I doubt it - other end attaches to steering rack bolts. I guess if I hit something hard enough I'd rather tweak the core support vs the subframe/steering rack components
                                        you could copy/get the hoop from the 'severe duty skid plates' from the guy on e30tech. i hit some big shit and no frame/steering rack damage with it.
                                          I'm not going crazy low or anything. This is just more of a precaution. The red46 plates are surprisingly beefy
