  4. '88 E30
'88 E30
savebigmoney
    wheel bearings/lock rings, rack boots/clamps, rear sway bar mount reinforcements came today
    getting closer
      Got the new wheel bearings and hubs pressed into the trailing arms today.
      Only things I'm waiting on is the skid plate & tierods (and the crap I haven't ordered yet)
      Gonna hopefully convince myself to work on it tomorrow
        This was more of a pain in the ass than I'd like to admit, especially by myself a584a19006dc4e29a38df37fc78704bb.jpg
        Butttttt the rear sway bar is in. ST 19mm. Can't imagine doing that with all the subframe crap in the way
          I can confirm the lack of joy that takes place during sway bar installs. The flatter cornering is all worth it
            With the subframe in place installing the larger sway involves both wheels off and creative threading the bar in from the passenger side. It works but is a pain. Key is to figure out the proper orientation before you start threading it in. Much easier your way.
              Rest of the parts have arrived.
              24v skid plate from red46
              Inner and outer e36 tierods
              Driveshaft nuts
              Spring pads
              Still need to order
              Suspension (coils?)
              Brake pads
              Front brake lines
              And probably some misc stuff
                sway bars suck third-ed and move to strike.
                glad you got a skid plate, they are 100% necessary for these swaps.
                  Only thing I'm nervous about is I have an aftermarket core support (my original one was kinda twisted and rusty) the aftermarket China ones work well enough, they are just quite thin and bendy. I think it should work because the red46 plate includes some hardware (drilling required) which includes a plate to sandwich the core support. Should be fine unless I go bounce off some rocks out in moab
                    You could always cut the core support open and stick a piece of square tube in there.
                    Wait, e30's aren't supposed to go to Moab? I better cancel my trip.....
                      We will see if the square tube is needed. For my uses, I doubt it - other end attaches to steering rack bolts. I guess if I hit something hard enough I'd rather tweak the core support vs the subframe/steering rack components
                        you could copy/get the hoop from the 'severe duty skid plates' from the guy on e30tech. i hit some big shit and no frame/steering rack damage with it.
                          I'm not going crazy low or anything. This is just more of a precaution. The red46 plates are surprisingly beefy
                            Steering rack back together with new lemforder shizzzz. Got the "alignment" (outer length) as close as I could. But my first stop is going to be to the alignment rack
                              Got tired and went inside. This is all the farther I made it. Bought new axle nuts. Promptly lost new axle nuts. Going to re use the old ones because there's nothing wrong with them, stupid shit like that frustrates me
                              "Hey my new parts showed up" "hey I already misplaced them" they didn't even make it out of the bag they were shipped in 😕
                              I hate my brain sometimes
                                Oh I also broke the cv boot clamp, so I'll need a new one of those as well
                                  That looks like a new axle nut it the last shot and it is surely out of its bag...
                                    That's the old one
                                      What tool did you use for the dust boot clamps?
                                        For the steering rack? My hands. When I take it to get it aligned I'll have them tighten up those clamps
                                          Zip ties ftw!!!
