  4. '88 E30
'88 E30
savebigmoney
    Got all the bushings in
    That's pretty much it
    Found out I'll need to move the union a tad
      well it happened, ordered about $1650 worth of crap tonight for it. (will get about $160 back in core)
      Still remaining to buy:
      coil overs
      brake pads & fluid (still on the fence about pads)
      front stainless brake lines
        What did you buy?
        • CMartC
          CMartC
          CMart
          coil overs
          Not sure if I asked/you answered, but any interest in my coilover setup or coilover/bbk setup
          Excursion 7.3
          E30 LS1
            coil overs
              wasnt m3 said:
              What did you buy?
              Inner/outer tierods
              Boots
              Clamps
              Lock plates
              Control arms
              Wheel bearings
              Wheel bearing circlips
              Axle lock plates
              Axle nuts
              Wheel bearings
              Brembo blanks
              Calipers
              Skid plate
              ST sways
              Akg sway bar mount reinforcement
              Dust shields
                coil overs
                I didn't even know you had stuff. Just bought brakes/calipers too.......
                • CMartC
                  CMartC
                  CMart
                  I've got a stance coilover/camber plate setup already welded up ready to bolt on. I also have a RX7 BBK that I could include.
                  Bad picture, but:
                  12736060_10102633118162083_1163972206_n
                  Excursion 7.3
                  E30 LS1
                    Do you know the spring rates?
                    I probably won't need the brake stuff as I've already ordered brakes/calipers
                      coil overs
                      That's some serious cash coming from the guy who didn't want to buy a radiator fan relay. 😛 Keep up the good work!!
                      • CMartC
                        CMartC
                        CMart
                        I want to say 8k front 9k rear but would I've to confirm that.
                        Excursion 7.3
                        E30 LS1
                          Brake supplies are in! Just need to get some front stainless lines and pads/fluid
                            wheel bearings/lock rings, rack boots/clamps, rear sway bar mount reinforcements came today
                            getting closer
                              Got the new wheel bearings and hubs pressed into the trailing arms today.
                              Only things I'm waiting on is the skid plate & tierods (and the crap I haven't ordered yet)
                              Gonna hopefully convince myself to work on it tomorrow
                                This was more of a pain in the ass than I'd like to admit, especially by myself a584a19006dc4e29a38df37fc78704bb.jpg
                                Butttttt the rear sway bar is in. ST 19mm. Can't imagine doing that with all the subframe crap in the way
                                  I can confirm the lack of joy that takes place during sway bar installs. The flatter cornering is all worth it
                                    With the subframe in place installing the larger sway involves both wheels off and creative threading the bar in from the passenger side. It works but is a pain. Key is to figure out the proper orientation before you start threading it in. Much easier your way.
                                      Rest of the parts have arrived.
                                      24v skid plate from red46
                                      Inner and outer e36 tierods
                                      Driveshaft nuts
                                      Spring pads
                                      Still need to order
                                      Suspension (coils?)
                                      Brake pads
                                      Front brake lines
                                      And probably some misc stuff
                                        sway bars suck third-ed and move to strike.
                                        glad you got a skid plate, they are 100% necessary for these swaps.
                                          Only thing I'm nervous about is I have an aftermarket core support (my original one was kinda twisted and rusty) the aftermarket China ones work well enough, they are just quite thin and bendy. I think it should work because the red46 plate includes some hardware (drilling required) which includes a plate to sandwich the core support. Should be fine unless I go bounce off some rocks out in moab
