  4. '88 E30
'88 E30
savebigmoney
    What did you buy?
    • CMartC
      CMartC
      CMart
      well it happened, ordered about $1650 worth of crap tonight for it. (will get about $160 back in core)
      Still remaining to buy:
      coil overs
      brake pads & fluid (still on the fence about pads)
      front stainless brake lines
      Not sure if I asked/you answered, but any interest in my coilover setup or coilover/bbk setup
      Excursion 7.3
      E30 LS1
        coil overs
          wasnt m3 said:
          What did you buy?
          Inner/outer tierods
          Boots
          Clamps
          Lock plates
          Control arms
          Wheel bearings
          Wheel bearing circlips
          Axle lock plates
          Axle nuts
          Wheel bearings
          Brembo blanks
          Calipers
          Skid plate
          ST sways
          Akg sway bar mount reinforcement
          Dust shields
            coil overs
            I didn't even know you had stuff. Just bought brakes/calipers too.......
            • CMartC
              CMartC
              CMart
              I've got a stance coilover/camber plate setup already welded up ready to bolt on. I also have a RX7 BBK that I could include.
              Bad picture, but:
              12736060_10102633118162083_1163972206_n
              Excursion 7.3
              E30 LS1
                Do you know the spring rates?
                I probably won't need the brake stuff as I've already ordered brakes/calipers
                  coil overs
                  That's some serious cash coming from the guy who didn't want to buy a radiator fan relay. 😛 Keep up the good work!!
                  • CMartC
                    CMartC
                    CMart
                    I want to say 8k front 9k rear but would I've to confirm that.
                    Excursion 7.3
                    E30 LS1
                      Brake supplies are in! Just need to get some front stainless lines and pads/fluid
                        wheel bearings/lock rings, rack boots/clamps, rear sway bar mount reinforcements came today
                        getting closer
                          Got the new wheel bearings and hubs pressed into the trailing arms today.
                          Only things I'm waiting on is the skid plate & tierods (and the crap I haven't ordered yet)
                          Gonna hopefully convince myself to work on it tomorrow
                            This was more of a pain in the ass than I'd like to admit, especially by myself a584a19006dc4e29a38df37fc78704bb.jpg
                            Butttttt the rear sway bar is in. ST 19mm. Can't imagine doing that with all the subframe crap in the way
                              I can confirm the lack of joy that takes place during sway bar installs. The flatter cornering is all worth it
                                With the subframe in place installing the larger sway involves both wheels off and creative threading the bar in from the passenger side. It works but is a pain. Key is to figure out the proper orientation before you start threading it in. Much easier your way.
                                  Rest of the parts have arrived.
                                  24v skid plate from red46
                                  Inner and outer e36 tierods
                                  Driveshaft nuts
                                  Spring pads
                                  Still need to order
                                  Suspension (coils?)
                                  Brake pads
                                  Front brake lines
                                  And probably some misc stuff
                                    sway bars suck third-ed and move to strike.
                                    glad you got a skid plate, they are 100% necessary for these swaps.
                                      Only thing I'm nervous about is I have an aftermarket core support (my original one was kinda twisted and rusty) the aftermarket China ones work well enough, they are just quite thin and bendy. I think it should work because the red46 plate includes some hardware (drilling required) which includes a plate to sandwich the core support. Should be fine unless I go bounce off some rocks out in moab
                                        You could always cut the core support open and stick a piece of square tube in there.
                                        Wait, e30's aren't supposed to go to Moab? I better cancel my trip.....
                                          We will see if the square tube is needed. For my uses, I doubt it - other end attaches to steering rack bolts. I guess if I hit something hard enough I'd rather tweak the core support vs the subframe/steering rack components
