  4. '88 E30
'88 E30
savebigmoney
    Grab some SS bolts to replace them and done!
      Good idea, but i don't care to buy bolts when the ones in there now work fine
        "Why buy new when slightly used will do?"
        Unmasked bolts are like unfolded side mirrors during proper winter storage mode.
        You should always mask your bolt
          Got all the bushings in
          That's pretty much it
          Found out I'll need to move the union a tad
            well it happened, ordered about $1650 worth of crap tonight for it. (will get about $160 back in core)
            Still remaining to buy:
            coil overs
            brake pads & fluid (still on the fence about pads)
            front stainless brake lines
              What did you buy?
              • CMartC
                CMartC
                CMart
                coil overs
                Not sure if I asked/you answered, but any interest in my coilover setup or coilover/bbk setup
                Excursion 7.3
                E30 LS1
                  coil overs
                    wasnt m3 said:
                    What did you buy?
                    Inner/outer tierods
                    Boots
                    Clamps
                    Lock plates
                    Control arms
                    Wheel bearings
                    Wheel bearing circlips
                    Axle lock plates
                    Axle nuts
                    Wheel bearings
                    Brembo blanks
                    Calipers
                    Skid plate
                    ST sways
                    Akg sway bar mount reinforcement
                    Dust shields
                      coil overs
                      I didn't even know you had stuff. Just bought brakes/calipers too.......
                      • CMartC
                        CMartC
                        CMart
                        I've got a stance coilover/camber plate setup already welded up ready to bolt on. I also have a RX7 BBK that I could include.
                        Bad picture, but:
                        12736060_10102633118162083_1163972206_n
                        Excursion 7.3
                        E30 LS1
                          Do you know the spring rates?
                          I probably won't need the brake stuff as I've already ordered brakes/calipers
                            coil overs
                            That's some serious cash coming from the guy who didn't want to buy a radiator fan relay. 😛 Keep up the good work!!
                            • CMartC
                              CMartC
                              CMart
                              I want to say 8k front 9k rear but would I've to confirm that.
                              Excursion 7.3
                              E30 LS1
                                Brake supplies are in! Just need to get some front stainless lines and pads/fluid
                                  wheel bearings/lock rings, rack boots/clamps, rear sway bar mount reinforcements came today
                                  getting closer
                                    Got the new wheel bearings and hubs pressed into the trailing arms today.
                                    Only things I'm waiting on is the skid plate & tierods (and the crap I haven't ordered yet)
                                    Gonna hopefully convince myself to work on it tomorrow
                                      This was more of a pain in the ass than I'd like to admit, especially by myself a584a19006dc4e29a38df37fc78704bb.jpg
                                      Butttttt the rear sway bar is in. ST 19mm. Can't imagine doing that with all the subframe crap in the way
                                        I can confirm the lack of joy that takes place during sway bar installs. The flatter cornering is all worth it
                                          With the subframe in place installing the larger sway involves both wheels off and creative threading the bar in from the passenger side. It works but is a pain. Key is to figure out the proper orientation before you start threading it in. Much easier your way.
