pistonse30
    DrLeadFoot said:
    You want to buy some random 3 in aluminum pipe?  Maybe some used coolant?  I'm running out of thangs to slang!
    Rowleym said:
    Ill buy the 3 in aluminum pipe. How much of it?
    hahahah. see!! worked out great
      I'll take a look in the garage tomorrow and see what I have.  I think 2-4 2ft pieces that include straight and 45 degree angles along with 4-6 cut up pieces that are 6-10".  I have some silicone connectors and t-bolt clamps that go together.  The pipe is painted black.
      HAHA  Who knew!
        It's a black out!
          well if its enough for me to finish my e36 charge piping, that would be radical. Ebay stuff? or actually weldable tubing?
            It is ebay stuff.  I did have it welded no problem.
              DrLeadFoot said:
              It's a black out!
              Much better!
                wasnt m3 said:
                It's a black out!
                Much better!
                It is weird seeing it like that after the blue being there for so long. I like it though!
                  Loads better. if you put the little panel in that covers that hole it'd be even nicer!
                    Installed the strut bar with 1/4" gap from the exhaust. After driving today the exhaust is now touching the strut bar. Metal expanding from the heat? My motor mounts are solid. I'll keep an eye out if the gap comes back.
                    In related news the wideband is back up and running. Next thing necessary to do is close up my plug gap. Now and then I'm getting breakup at high rpms.
                    • andyhundleyA
                      andyhundleyA
                      andyhundley
                      DrLeadFoot said:
                      Who has re-keyed their locks?  Please school me on this guys!
                      We (wilde toyota) take all of our lock and ignition cylinders to get recoded at Security Plus Locksmith on Loomis and I-43. The guy is old school and is very resonable and has roughly 1 day turn around time.
                        Say the downpipe is 3" O.D. and is 304 stainless, it would only grow 0.010" radially at 700F. Compound that with the expansion of the turbine housing, manifold, block, head, and strut brace and (without actually doing  the  calculations) you might be approaching 0.090" total expansion. I would suspect the engine is shifting back and forth on the engine mounts, yes even the solid mounts.
                        Make sure the rubber buffer #15 is installed. It slams up against the back of the subframe under braking so the engine mounts dont have to restrain the powertrain longitudinally all by themselves.
                          That was deep, breh!!  Great info and thought process.
                          I don't think I've ever seen that bracket!  You got to love previous owners.
                          Thanks for the info.
                            While waiting for parts to arrive.
                            Happy Thanksgiving!
                              Looks fantastic!!!
                                do you shoot most of these with your phone?
                                because if so... damn.
                                :cool:
                                  :cool:
                                  Haha. The Samsung isn't that good. I got a canon t2i with an upgraded lens.
                                  ClassE said:
                                  Looks fantastic!!!
                                  Thanks!!
                                    Got some new plugs.
                                      4 BOUGIES
                                      nice classic issue of R&T there too
                                        1500 miles on these plugs.
                                        I got the new ones all pointed EXACTLY with the open end pointed away from the intake to help reduce spark blow out. Gapped exactly to .021 and yes I did double check! No breakup at all!! She good.
                                          DrLeadFoot said:
                                          1500 miles on these BOUGIES
                                          I got the new ones all pointed exactly with the open end pointed away from the intake to help reduce spark blow out. Gapped exactly to .021 and yes I did double check! No breakup at all!! She good.
