pistonse30
    DrLeadFoot said:
    It's a black out!
    Much better!
      wasnt m3 said:
      It's a black out!
      Much better!
      It is weird seeing it like that after the blue being there for so long. I like it though!
        Loads better. if you put the little panel in that covers that hole it'd be even nicer!
          Installed the strut bar with 1/4" gap from the exhaust. After driving today the exhaust is now touching the strut bar. Metal expanding from the heat? My motor mounts are solid. I'll keep an eye out if the gap comes back.
          In related news the wideband is back up and running. Next thing necessary to do is close up my plug gap. Now and then I'm getting breakup at high rpms.
          • andyhundleyA
            andyhundleyA
            andyhundley
            DrLeadFoot said:
            Who has re-keyed their locks?  Please school me on this guys!
            We (wilde toyota) take all of our lock and ignition cylinders to get recoded at Security Plus Locksmith on Loomis and I-43. The guy is old school and is very resonable and has roughly 1 day turn around time.
              Say the downpipe is 3" O.D. and is 304 stainless, it would only grow 0.010" radially at 700F. Compound that with the expansion of the turbine housing, manifold, block, head, and strut brace and (without actually doing  the  calculations) you might be approaching 0.090" total expansion. I would suspect the engine is shifting back and forth on the engine mounts, yes even the solid mounts.
              Make sure the rubber buffer #15 is installed. It slams up against the back of the subframe under braking so the engine mounts dont have to restrain the powertrain longitudinally all by themselves.
                That was deep, breh!!  Great info and thought process.
                I don't think I've ever seen that bracket!  You got to love previous owners.
                Thanks for the info.
                  While waiting for parts to arrive.
                  Happy Thanksgiving!
                    Looks fantastic!!!
                      do you shoot most of these with your phone?
                      because if so... damn.
                      :cool:
                        :cool:
                        Haha. The Samsung isn't that good. I got a canon t2i with an upgraded lens.
                        ClassE said:
                        Looks fantastic!!!
                        Thanks!!
                          Got some new plugs.
                            4 BOUGIES
                            nice classic issue of R&T there too
                              1500 miles on these plugs.
                              I got the new ones all pointed EXACTLY with the open end pointed away from the intake to help reduce spark blow out. Gapped exactly to .021 and yes I did double check! No breakup at all!! She good.
                                DrLeadFoot said:
                                1500 miles on these BOUGIES
                                I got the new ones all pointed exactly with the open end pointed away from the intake to help reduce spark blow out. Gapped exactly to .021 and yes I did double check! No breakup at all!! She good.
                                  Snap hooked it up with his smoke tester and my system looks to be good with exception on my turbine housing.  That is leaking very badly.  I have a video of it on instagram @drleadfoot
                                    O-ring bad I assume?
                                      The turbo has 2100 miles on it.  I hope it isn't going to blow them out that fast.  High temp RTV sealant?  Some guys have done this with good results from a brief google search.
                                        glad to see you found/confirmed your leak.  you must have been burning some low-grade leaves otherwise you wouldnt have needed the water spritzer.
                                          You should see my garage. There are too many fire hazards to whip up a bonfire. I tried but I don't think I have any leaks except for the turbo cold side. (Video on instagram. Here soon.) Once my silicone dries up tomorrow I'll smoke the turbo side and see is she puff. #ifshesmokesshepokes
