Chapter GMW | E30 LS1 (starting on post #1427)
Car looks great John! IMO, it would look much cleaner with some black elbows for the intercooler.
Thanks buddy!
Pegasus only had the blue ones. Black ones are on the list for sure.
Writing down another update to keep me organized.
Things to do:
- Swing by radio shack for a 5amp inline fuse for the wideband brain.
- Buy a new VDO oil pressure gauge that works with my sending unit.
- Install glove box
- Install trunk lock.
- I also need to cut some more of my fenders off in the rear.
- Clean up the grill and fender mounts. #easy
Who has re-keyed their locks? Please school me on this guys!
After doing some work to the BOV I found out that I had a pinched ICV barbed hose fitting which had to be leaking badly. I kind of already mentioned this...Now can this snow go away?!?!
Agree with TJ, this thing is tits, aside from those blue couplers.
Idk if this was mentioned, but what turbo are you running?
The turbo is a TO4E 67mm .82 T3 P-trim J-bearing. Not huge but I'm not going for 900hp. I want to max this out to its full efficiency. I still have to figure out what that will be though. HA!
Can you paint silicone? I'm trying to get away from this money pit nickel and dimein' me unless I really need something. (That reminds me I need to order some transmission mounts. My passenger side mount is ripping!)
Just ordered 10 NGK 4554 plugs. Gonna gap them to .021 and have them all pointing open end away from the intake. Because RACECAR!
Also just ordered my Condor Speed Shop trans. mounts.
^ sell some more random parts in your garage!!
that way you can just keep buying stuff for this and never stop this thread!!
You want to buy some random 3 in aluminum pipe? Maybe some used coolant? I'm running out of thangs to slang!
Ill buy the 3 in aluminum pipe. How much of it?
hahahah. see!! worked out great
I'll take a look in the garage tomorrow and see what I have. I think 2-4 2ft pieces that include straight and 45 degree angles along with 4-6 cut up pieces that are 6-10". I have some silicone connectors and t-bolt clamps that go together. The pipe is painted black.
HAHA Who knew!
It's a black out!
well if its enough for me to finish my e36 charge piping, that would be radical. Ebay stuff? or actually weldable tubing?
It is ebay stuff. I did have it welded no problem.
It's a black out!
Much better!
It's a black out!
Much better!
It is weird seeing it like that after the blue being there for so long. I like it though!
Installed the strut bar with 1/4" gap from the exhaust. After driving today the exhaust is now touching the strut bar. Metal expanding from the heat? My motor mounts are solid. I'll keep an eye out if the gap comes back.
In related news the wideband is back up and running. Next thing necessary to do is close up my plug gap. Now and then I'm getting breakup at high rpms.
We (wilde toyota) take all of our lock and ignition cylinders to get recoded at Security Plus Locksmith on Loomis and I-43. The guy is old school and is very resonable and has roughly 1 day turn around time.
