pistonse30
    Brian. said:
    Agree with TJ, this thing is tits, aside from those blue couplers.
    Idk if this was mentioned, but what turbo are you running?
    The turbo is a TO4E 67mm .82 T3 P-trim J-bearing.  Not huge but I'm not going for 900hp.  I want to max this out to its full efficiency.  I still have to figure out what that will be though.  HA!
    Can you paint silicone?  I'm trying to get away from this money pit nickel and dimein' me unless I really need something. (That reminds me I need to order some transmission mounts.  My passenger side mount is ripping!)
      Just ordered 10 NGK 4554 plugs.  Gonna gap them to .021 and have them all pointing open end away from the intake.  Because RACECAR!
        Also just ordered my Condor Speed Shop trans. mounts.
          ^ sell some more random parts in your garage!!
          that way you can just keep buying stuff for this and never stop this thread!!
            You want to buy some random 3 in aluminum pipe?  Maybe some used coolant?  I'm running out of thangs to slang!
              Ill buy the 3 in aluminum pipe. How much of it?
                hahahah. see!! worked out great
                  I'll take a look in the garage tomorrow and see what I have.  I think 2-4 2ft pieces that include straight and 45 degree angles along with 4-6 cut up pieces that are 6-10".  I have some silicone connectors and t-bolt clamps that go together.  The pipe is painted black.
                  HAHA  Who knew!
                    It's a black out!
                      well if its enough for me to finish my e36 charge piping, that would be radical. Ebay stuff? or actually weldable tubing?
                        It is ebay stuff.  I did have it welded no problem.
                          DrLeadFoot said:
                          It's a black out!
                          Much better!
                            wasnt m3 said:
                            It's a black out!
                            Much better!
                            It is weird seeing it like that after the blue being there for so long. I like it though!
                              Loads better. if you put the little panel in that covers that hole it'd be even nicer!
                                Installed the strut bar with 1/4" gap from the exhaust. After driving today the exhaust is now touching the strut bar. Metal expanding from the heat? My motor mounts are solid. I'll keep an eye out if the gap comes back.
                                In related news the wideband is back up and running. Next thing necessary to do is close up my plug gap. Now and then I'm getting breakup at high rpms.
                                • andyhundleyA
                                  andyhundleyA
                                  andyhundley
                                  DrLeadFoot said:
                                  Who has re-keyed their locks?  Please school me on this guys!
                                  We (wilde toyota) take all of our lock and ignition cylinders to get recoded at Security Plus Locksmith on Loomis and I-43. The guy is old school and is very resonable and has roughly 1 day turn around time.
                                    Say the downpipe is 3" O.D. and is 304 stainless, it would only grow 0.010" radially at 700F. Compound that with the expansion of the turbine housing, manifold, block, head, and strut brace and (without actually doing  the  calculations) you might be approaching 0.090" total expansion. I would suspect the engine is shifting back and forth on the engine mounts, yes even the solid mounts.
                                    Make sure the rubber buffer #15 is installed. It slams up against the back of the subframe under braking so the engine mounts dont have to restrain the powertrain longitudinally all by themselves.
                                      That was deep, breh!!  Great info and thought process.
                                      I don't think I've ever seen that bracket!  You got to love previous owners.
                                      Thanks for the info.
                                        While waiting for parts to arrive.
                                        Happy Thanksgiving!
                                          Looks fantastic!!!
