  4. E21 project thread
E21 project thread
    Small Update:
    I havent touched the car in weeks, but finally got some time, motivation, and good enough weather to do something. I went ahead and removed the shifter plate and all other necessary parts that will be replaced. I now know why my shifter was so sloppy even when in gear.
    Video of shifter before removal.
    Posted Image
    Wish I would have gotten a picture from underneath, oh well tho. I had to do some cutting and grinding with the dremel in order to remove the rear support pieces. The bolt/nut were completely. Also, the PO thought of the bright idea of putting a long bolt all the way through the tunnel and plate with a nut on the underside to hold things steady. How in the hell does one person hold the bolt head in the cab while removing the nut from under the car? I ended up cutting the nut with the dremel until i could loosen it a tad. Then I went into the cab and cut the head of the bolt off. Was a pain in the ass, but got it done eventually. After that the entire assembly could be taken off.
    Old parts after removal.
    Posted Image
    Posted Image
    Posted Image
    Here is the new plate vs. the old plate.
    Posted Image
    And after dissambling everything and replacing all parts with brand new parts from AutohausAZ except the shifter itself.
    Posted Image
    I am waiting for more por-15 to show up before installing everything back on the car. I want to hit the underside of everything with por-15. I will hopefully remember to take a pic of before/after the por-15 like usual. I will also take another video to compare the "slop" from before/after. Hopefully there will be none. *crosses fingers* Thats it for now.
      Nice vid
      Its only going to get easier to be motivated as the days get longer and weather gets warmer. BRING IT ON!!!
        Mine's just as sloppy on the e28, so I'll need to do the same. Keep the updates coming!
          Thanks guys and certainly will do!!
          • StewCrewS
            StewCrewS
            StewCrew
            Im loving that copper rear end. Cant say Ive seen that before. This car is going to feel brand new once its all back together. Keep up the work man, its looking great!
              Thanks man! I hope its a huge improvement, which I cant see it NOT being. Lol! Your car is coming along outstanding too by the way.
                Last weekend I was able to get the shifter assembly finished and installed. I replaced all parts except the shifter itself. Here is the video of the shifter slop after the installation. Still has a bit in gear, which I am a little disappointed about. Anybody have any suggestions on removing the slop completely?
                Posted Image
                Here it all is installed.
                Posted Image
                While waiting for the POR-15 to dry underneath the car around the shifter area, I decided to sand down, remove the surface rust, and POR-15 the rear valance. The before picture of the rear valance can be seen in a previous post. Here it is all rust proofed and looking good.
                Posted Image
                After the POR-15 was all dry, I went ahead and installed my rear euro bumper brackets that made and powdercoated previously. I just need to measure the space for the lower bolt so I can pick up a spacer and they will be installed for good.
                Posted Image
                Posted Image
                With those bolted up, I went ahead and installed the front euro bumper brackets that I powdercoated previously as well. These were simple since they bolted to the stock bumper shock points.
                Posted Image
                Posted Image
                Posted Image
                Posted Image
                That was pretty much it for last weekend. Will hopefully get some more work done this weekend as well. Just to end it off, here is a shot of the work space I built for the beam for during the winter. Definitely came in handy with a nice propane turbo heater too!
                Posted Image
                http://i144.photobucket.com/albums/r175/bassboy3313/62af4a92cd18_40457305-3bd8-4591-8665-a4b6aff89562th450tw610_zps6492a073.jpg
                  Does that tent hold heat pretty well?
                    It'll hold heat 100x better then just being outside.. Since it has no "porous" sides/top" It'll retain heat better then say a tarp. It's sealed. That and it'll keep you out of the wind= 1000000x better to work in then just out side in general. I've thought about purchasing oone for the E28. but they're like... $200+ for one that you can actually manvure in!
                      Yeah I've thought about it too, thats why I'm curious :P
                        They dont make a DSSR for the E21. I bought one for my car and you've felt how snug it is.
                        DIY:
                        http://www.r3vlimited.com/board/showthread.php?t=192531
                          It hold heat VERY well. I have to turn the heater down/off after only 5 minutes of running since it gets too hot in there sometimes. I got this one at harbor freight. It was $200+, on sale for $170, plus I had a 20% off coupon. I think I made out pretty damn good on it. Wasnt that difficult to put up either. Would have gone a lot faster with two people, but I was able to put it up by myself with little fuss.
                          DIY:
                          I will definitely have to look into that. Thanks!
                            Wow! It has been quite a bit since I updated this thread. My bad. Haven’t been able to work on the car in a while, but I got quite a bit done the past few weekends I would say. I bought all new front vented rotors and calipers from rock auto as well as brake hoses and hard lines. I used the duplicolor caliper paint for the first time on these things and I have to say, that paint is fantastic! Goes on so smooth and dries super quick.
                            I painted the rotor hats, calipers and the new slave cylinder with the caliper paint.
                            610497f03650c5d02186-40a7-477b-8a19-73a
                            163d740f95c382f98a31-222f-4cb7-b0e1-c7a
                            I then installed the new slave cylinder and reworked the hard lines since the PO had rubber hose going into a non-brake rated rubber hose then into hard line into slave. That was not working for me. Lol.
                            After that it was time to install the front brakes after they dried. I loaded up the calipers with some repco metal master pads I had previously gotten. The rotors and calipers went on super easy (obviously) but it was a bit of a push and pull to bend the new hard lines, but I managed.
                            Old brakes out
                            New brakes in
                            Next on the list was getting the new trans mount in while I still had driveshaft disconnected from doing the shifter plate/rod replacement. This was a lot easier then I could have imagined. I also replaced the guibo with a new one while I was in there as well.
                            Old trans mount on left, new on right
                            Guibo comparison – Old on right, new on left
                            and installed
                              Wow! the painted rotor hats look awesome!! nice work man! The vented front brake upgrade with new pads and the rear disk conversion is going to stop SO much better!!
                                NICE!!
                                  That guibo is gonna feel nice! Rotors look cool too
                                    Although no pictures right now, this weekend the subframe went back in!!!!! Man that went a lot better than I expected all thanks to Brian (aka snap oversteer) who helped put that sucker in. Will get pics when I get the chance.
                                      picsoritdidnthappen : )
                                      • JeffJ
                                        JeffJ
                                        Jeff
                                        Wish my rotors looked like that
                                        1976 530i e12
                                        1990 325ix e30
                                        1992 325i e36
                                        1995 740il e38
                                        2001 330xi e46
                                        ^More to come :)
                                          i like old crappy rotors, adds character
