  4. E21 project thread
E21 project thread
    Thanks guys and certainly will do!!
    • StewCrewS
      StewCrewS
      StewCrew
      Im loving that copper rear end. Cant say Ive seen that before. This car is going to feel brand new once its all back together. Keep up the work man, its looking great!
        Thanks man! I hope its a huge improvement, which I cant see it NOT being. Lol! Your car is coming along outstanding too by the way.
          Last weekend I was able to get the shifter assembly finished and installed. I replaced all parts except the shifter itself. Here is the video of the shifter slop after the installation. Still has a bit in gear, which I am a little disappointed about. Anybody have any suggestions on removing the slop completely?
          Posted Image
          Here it all is installed.
          Posted Image
          While waiting for the POR-15 to dry underneath the car around the shifter area, I decided to sand down, remove the surface rust, and POR-15 the rear valance. The before picture of the rear valance can be seen in a previous post. Here it is all rust proofed and looking good.
          Posted Image
          After the POR-15 was all dry, I went ahead and installed my rear euro bumper brackets that made and powdercoated previously. I just need to measure the space for the lower bolt so I can pick up a spacer and they will be installed for good.
          Posted Image
          Posted Image
          With those bolted up, I went ahead and installed the front euro bumper brackets that I powdercoated previously as well. These were simple since they bolted to the stock bumper shock points.
          Posted Image
          Posted Image
          Posted Image
          Posted Image
          That was pretty much it for last weekend. Will hopefully get some more work done this weekend as well. Just to end it off, here is a shot of the work space I built for the beam for during the winter. Definitely came in handy with a nice propane turbo heater too!
          Posted Image
          http://i144.photobucket.com/albums/r175/bassboy3313/62af4a92cd18_40457305-3bd8-4591-8665-a4b6aff89562th450tw610_zps6492a073.jpg
            Does that tent hold heat pretty well?
              It'll hold heat 100x better then just being outside.. Since it has no "porous" sides/top" It'll retain heat better then say a tarp. It's sealed. That and it'll keep you out of the wind= 1000000x better to work in then just out side in general. I've thought about purchasing oone for the E28. but they're like... $200+ for one that you can actually manvure in!
                Yeah I've thought about it too, thats why I'm curious :P
                  They dont make a DSSR for the E21. I bought one for my car and you've felt how snug it is.
                  DIY:
                  http://www.r3vlimited.com/board/showthread.php?t=192531
                    It hold heat VERY well. I have to turn the heater down/off after only 5 minutes of running since it gets too hot in there sometimes. I got this one at harbor freight. It was $200+, on sale for $170, plus I had a 20% off coupon. I think I made out pretty damn good on it. Wasnt that difficult to put up either. Would have gone a lot faster with two people, but I was able to put it up by myself with little fuss.
                    DIY:
                    I will definitely have to look into that. Thanks!
                      Wow! It has been quite a bit since I updated this thread. My bad. Haven’t been able to work on the car in a while, but I got quite a bit done the past few weekends I would say. I bought all new front vented rotors and calipers from rock auto as well as brake hoses and hard lines. I used the duplicolor caliper paint for the first time on these things and I have to say, that paint is fantastic! Goes on so smooth and dries super quick.
                      I painted the rotor hats, calipers and the new slave cylinder with the caliper paint.
                      610497f03650c5d02186-40a7-477b-8a19-73a
                      163d740f95c382f98a31-222f-4cb7-b0e1-c7a
                      I then installed the new slave cylinder and reworked the hard lines since the PO had rubber hose going into a non-brake rated rubber hose then into hard line into slave. That was not working for me. Lol.
                      After that it was time to install the front brakes after they dried. I loaded up the calipers with some repco metal master pads I had previously gotten. The rotors and calipers went on super easy (obviously) but it was a bit of a push and pull to bend the new hard lines, but I managed.
                      Old brakes out
                      New brakes in
                      Next on the list was getting the new trans mount in while I still had driveshaft disconnected from doing the shifter plate/rod replacement. This was a lot easier then I could have imagined. I also replaced the guibo with a new one while I was in there as well.
                      Old trans mount on left, new on right
                      Guibo comparison – Old on right, new on left
                      and installed
                        Wow! the painted rotor hats look awesome!! nice work man! The vented front brake upgrade with new pads and the rear disk conversion is going to stop SO much better!!
                          NICE!!
                            That guibo is gonna feel nice! Rotors look cool too
                              Although no pictures right now, this weekend the subframe went back in!!!!! Man that went a lot better than I expected all thanks to Brian (aka snap oversteer) who helped put that sucker in. Will get pics when I get the chance.
                                picsoritdidnthappen : )
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  Wish my rotors looked like that
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                    i like old crappy rotors, adds character
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      ^ sometimes i worrie about you
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                          ^hhaha
                                          hopefully by repeatedly bumping this thread with random nonsense bassboy will post pics!
