  4. E21 project thread
E21 project thread
    Sometimes I felt like I enjoy taking rides in this car more than driving my own. Theres something charming about an e21 brought back from the edge of death which is now running a turbo with K-jet and operates by magic.
    This car isn't being built to a specific crowd pleasing formula that is proven to work, like an E30 with Style 5's, mtech 2 bodywork, shadowline and just the right stance. And because its so different, it is awesome!
      Different is good! I approve :) That copper paint is really cool and those yellow bushings are too! Will be fun to look under the car and see it in person.
        .............oh, and
        Posted Image
        you. me. this friday night on Ryan...'s front lawn.
          UPDATE:
          So since the last post, I have gotten a little more done, but not as much as I hoped. Been pretty busy and more important things came up. The rear subframe assembly has been completed to the point where the brakes and reman axles can now be installed once I pick those up. The LSD has been painted and installed along with the sway bar and bushings.
          Posted Image
          Before installing the subframe assembly back on the car, I wanted to clean up the underbody of the car first. Surprisingly, for a 30 year old Wisconsin car, there wasn’t much rust at all. I was surprised for sure. Here are the only spots of rust I found.
          Posted Image
          Posted Image
          I also removed the fuel parts back there since they were a little rusty and the brackets were broken. I am going to be using a spare set of brackets for the fuel stuff as well as a spare accumulator that is in better condition.
          Posted Image
          After a little wire brushing, metal acid etching, and some por-15 this is what it looks like. Just got to underbody coat it all and its ready for the subframe assembly.
          Posted Image
          Posted Image
          Posted Image
          I tend to jump around when doing this many projects at once. So, along with working on the stuff already posted I also managed to removed the valve cover of the engine and give it a new paint job. Its not the best, but it will do for now. Can always sand blast it back down later if I wanted. Im not worried about it.
          Posted Image
          I also got the trigger wheel/pulley setup done for the megajolt install as well.
          before
          Posted Image
          and after some lathe work and grinding
          Posted Image
          That’s it for now. Will be a slow process, but completion will be reached by late spring/early summer at latest. I will keep updating as I go, so feel free to keep checking in. Thanks guys!!
            Well, much hasn’t really happened lately since I have been busy and also am dealing with a personal hardship. I finally got myself up and motivated to go out and do something today, but not much unfortunately.
            I finished por-15’ing and undercoating things under the rear as well as reinstalled the fuel parts and brackets back up there. I went ahead and replaced the fuel hose that went from the tank sender to the external pump as well since it was in bad condition. Sorry I never took pics of that. I am waiting to install the subframe since I want to replace the ebrake cables and remove driveshaft so I can replace the shifter plate and necessary parts too.
            Like I mentioned I tend to jump around since I have quite a few projects going on at the same time. I went ahead and removed the rear bumper since I will be putting on the euro bumpers I received a couple weeks back. Still haven’t gotten those fully out of the box to take pics of yet. The bumper shocks sure were rusty and left piles of rust dust inside the rails that will need to be vacuumed out.
            Posted Image
            Bumper removed and time to clean that surface rust up and por-15 it all.
            Posted Image
            I also received my front euro bumper bracket adapters this week so I decided to powdercoat those as well as the rear adapters I made.
            Rear adapters
            Posted Image
            Posted Image
            Posted Image
            Front adapters
            Posted Image
            Posted Image
            Posted Image
            That was pretty much it for today. Slow but steady I think. Hopefully things will start picking up, but who knows. Thanks for looking!
              You and Jake are the only ones getting work done around here (posting pics for proof at least :P )
              And you forgot to mention you bought some Bilstein sports for the front!
              With those euro bumpers you really do have just about every rare-ish/desirable E21 part for your car now.
                Lookin good man! :)
                  Thanks guys. And yes you are right, I did in fact buy front billy sports the other day. Hopefully they work as good as the guy says they do. Then all I need are some billy sports for the rear or get the ones I have rebuilt by bilstein. Then I can start mocking up the coilover sleeves.
                    Post pictures of the car!
                      Small Update:
                      I havent touched the car in weeks, but finally got some time, motivation, and good enough weather to do something. I went ahead and removed the shifter plate and all other necessary parts that will be replaced. I now know why my shifter was so sloppy even when in gear.
                      Video of shifter before removal.
                      Posted Image
                      Wish I would have gotten a picture from underneath, oh well tho. I had to do some cutting and grinding with the dremel in order to remove the rear support pieces. The bolt/nut were completely. Also, the PO thought of the bright idea of putting a long bolt all the way through the tunnel and plate with a nut on the underside to hold things steady. How in the hell does one person hold the bolt head in the cab while removing the nut from under the car? I ended up cutting the nut with the dremel until i could loosen it a tad. Then I went into the cab and cut the head of the bolt off. Was a pain in the ass, but got it done eventually. After that the entire assembly could be taken off.
                      Old parts after removal.
                      Posted Image
                      Posted Image
                      Posted Image
                      Here is the new plate vs. the old plate.
                      Posted Image
                      And after dissambling everything and replacing all parts with brand new parts from AutohausAZ except the shifter itself.
                      Posted Image
                      I am waiting for more por-15 to show up before installing everything back on the car. I want to hit the underside of everything with por-15. I will hopefully remember to take a pic of before/after the por-15 like usual. I will also take another video to compare the "slop" from before/after. Hopefully there will be none. *crosses fingers* Thats it for now.
                        Nice vid
                        Its only going to get easier to be motivated as the days get longer and weather gets warmer. BRING IT ON!!!
                          Mine's just as sloppy on the e28, so I'll need to do the same. Keep the updates coming!
                            Thanks guys and certainly will do!!
                            • StewCrewS
                              StewCrewS
                              StewCrew
                              Im loving that copper rear end. Cant say Ive seen that before. This car is going to feel brand new once its all back together. Keep up the work man, its looking great!
                                Thanks man! I hope its a huge improvement, which I cant see it NOT being. Lol! Your car is coming along outstanding too by the way.
                                  Last weekend I was able to get the shifter assembly finished and installed. I replaced all parts except the shifter itself. Here is the video of the shifter slop after the installation. Still has a bit in gear, which I am a little disappointed about. Anybody have any suggestions on removing the slop completely?
                                  Posted Image
                                  Here it all is installed.
                                  Posted Image
                                  While waiting for the POR-15 to dry underneath the car around the shifter area, I decided to sand down, remove the surface rust, and POR-15 the rear valance. The before picture of the rear valance can be seen in a previous post. Here it is all rust proofed and looking good.
                                  Posted Image
                                  After the POR-15 was all dry, I went ahead and installed my rear euro bumper brackets that made and powdercoated previously. I just need to measure the space for the lower bolt so I can pick up a spacer and they will be installed for good.
                                  Posted Image
                                  Posted Image
                                  With those bolted up, I went ahead and installed the front euro bumper brackets that I powdercoated previously as well. These were simple since they bolted to the stock bumper shock points.
                                  Posted Image
                                  Posted Image
                                  Posted Image
                                  Posted Image
                                  That was pretty much it for last weekend. Will hopefully get some more work done this weekend as well. Just to end it off, here is a shot of the work space I built for the beam for during the winter. Definitely came in handy with a nice propane turbo heater too!
                                  Posted Image
                                  http://i144.photobucket.com/albums/r175/bassboy3313/62af4a92cd18_40457305-3bd8-4591-8665-a4b6aff89562th450tw610_zps6492a073.jpg
                                    Does that tent hold heat pretty well?
                                      It'll hold heat 100x better then just being outside.. Since it has no "porous" sides/top" It'll retain heat better then say a tarp. It's sealed. That and it'll keep you out of the wind= 1000000x better to work in then just out side in general. I've thought about purchasing oone for the E28. but they're like... $200+ for one that you can actually manvure in!
                                        Yeah I've thought about it too, thats why I'm curious :P
                                          They dont make a DSSR for the E21. I bought one for my car and you've felt how snug it is.
                                          DIY:
                                          http://www.r3vlimited.com/board/showthread.php?t=192531
