  4. E21 project thread
E21 project thread
    They dont make a DSSR for the E21. I bought one for my car and you've felt how snug it is.
    DIY:
    http://www.r3vlimited.com/board/showthread.php?t=192531
      CYoung said:
      Does that tent hold heat pretty well?
      Brian said:
      It'll hold heat 100x better then just being outside.. Since it has no "porous" sides/top" It'll retain heat better then say a tarp. It's sealed. That and it'll keep you out of the wind= 1000000x better to work in then just out side in general. I've thought about purchasing oone for the E28. but they're like... $200+ for one that you can actually manvure in!
      It hold heat VERY well. I have to turn the heater down/off after only 5 minutes of running since it gets too hot in there sometimes. I got this one at harbor freight. It was $200+, on sale for $170, plus I had a 20% off coupon. I think I made out pretty damn good on it. Wasnt that difficult to put up either. Would have gone a lot faster with two people, but I was able to put it up by myself with little fuss.
      DIY:
      I will definitely have to look into that. Thanks!
        Wow! It has been quite a bit since I updated this thread. My bad. Haven’t been able to work on the car in a while, but I got quite a bit done the past few weekends I would say. I bought all new front vented rotors and calipers from rock auto as well as brake hoses and hard lines. I used the duplicolor caliper paint for the first time on these things and I have to say, that paint is fantastic! Goes on so smooth and dries super quick.
        I painted the rotor hats, calipers and the new slave cylinder with the caliper paint.
        610497f03650c5d02186-40a7-477b-8a19-73a
        163d740f95c382f98a31-222f-4cb7-b0e1-c7a
        I then installed the new slave cylinder and reworked the hard lines since the PO had rubber hose going into a non-brake rated rubber hose then into hard line into slave. That was not working for me. Lol.
        After that it was time to install the front brakes after they dried. I loaded up the calipers with some repco metal master pads I had previously gotten. The rotors and calipers went on super easy (obviously) but it was a bit of a push and pull to bend the new hard lines, but I managed.
        Old brakes out
        New brakes in
        Next on the list was getting the new trans mount in while I still had driveshaft disconnected from doing the shifter plate/rod replacement. This was a lot easier then I could have imagined. I also replaced the guibo with a new one while I was in there as well.
        Old trans mount on left, new on right
        Guibo comparison – Old on right, new on left
        and installed
          Wow! the painted rotor hats look awesome!! nice work man! The vented front brake upgrade with new pads and the rear disk conversion is going to stop SO much better!!
            NICE!!
              That guibo is gonna feel nice! Rotors look cool too
                Although no pictures right now, this weekend the subframe went back in!!!!! Man that went a lot better than I expected all thanks to Brian (aka snap oversteer) who helped put that sucker in. Will get pics when I get the chance.
                  picsoritdidnthappen : )
                  • JeffJ
                    JeffJ
                    Jeff
                    Wish my rotors looked like that
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      i like old crappy rotors, adds character
                      • JeffJ
                        JeffJ
                        Jeff
                        ^ sometimes i worrie about you
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                            ^hhaha
                            hopefully by repeatedly bumping this thread with random nonsense bassboy will post pics!
                              You guys are killing me! Haha! Will grab some pics now.
                                Here you go guys! Subframe is in!
                                  i like clean undercarriages
                                    Looking good!
                                      awhhh yeah!
                                        That's beautiful.
                                          I got the parking brakes installed, cables/hoses/lines all put on and the calipers/rotors on the rear this weekend. All-in-all a pretty productive weekend considering I spent my Saturday taking an 8 hour fundamentals of engineering (FE) exam.
                                          Started working on the rear coilover setup. I have brand new bilstein sports that I installed the coilover sleeves on.
                                          From the looks of things, I am going to need either longer springs or helper springs to make this work. I am still new to the whole diy coilover stuff, so it will definitely be a learning experience.
