  4. E30 M52
E30 M52
    14590867121628019839308150775123044262
      Seeing this makes me feel quite a bit better actually.
        That is: AMAZING.
          I got the intake cam installed and torqu... no I didnt. The last 2 stripped.
          Im even using a brand new torque wrench with a certificate of calibration and everything.
          Stupid 24V
          Update: fixed 1 of the 3 remaining stripped holes. Tap fell and rolled somewhere. 10 minutes of sweaty searching and I quit. I'll just buy a new one and find the old one right after I start using it.
          Let me also tell you of the struggle of getting a straight drill/tap with the head on the engine hanging from an engine hoist (i cannot rest it on something now because the pan is off)
          This is a common occurrence on the Toyota 3VZE which is also a shitty engine
            run it.
              This is my lifter bucket keeper-upper so the lifters dont fall out when removing/installing the cam trays.
              Steel rod with some magnets
              I was going to assemble the oil pump with the E34 pickup tube but noticed a knick in the pump outer ring. 7cef1722c82b0915ffa066a43c5373be.jpg
              (Assembled view so you can see what part I am talking about)
              This part isnt under too much stress but it gets loaded cyclically and its a perfect storm for a crack to form from fatigue+heat. If the ring opens up at all it will jam/sieze
              I am ordering a new one and will replace the pressure relief valve components while im at it. I wasnt planning on it but its a Wednesday and I had KFC for dinner so I guess I will
              This is the bracket for the rear-sump pickup tube. It gets bent/broken off for fitment of the front sump pan.
              My progress is at a crossroads until parts arrive and there isnt too much I can do to keep moving forward so I think I will use the time to modify the shift linkage and shift carrier so i can drop them off with Mr. Welderdude.
              I picked up the oil pan from him monday
              • JeffJ
                JeffJ
                Jeff
                Nice update! I love the idea with the magnets holding the lifters.
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                  Chugga chugga chugga. You going to be driving this to the fall meet?
                  • The Full BananaT
                    The Full BananaT
                    The Full Banana
                    Are we there yet?
                      This E30 is not likely to be road legal in 2017. If I didn't have to finish the exhaust and re-register it I would say yes. I am doing what I can to get back to enjoying the car.
                      Tom,  cool your tits, we just got Dairy Queen, DONT YOU LIKE DAIRY QUEEN!?!?!?
                        Test fitting
                          Mid engine swap?  At least open the door...
                            I figured popping the sunroof would give me the clearance I needed but thanks for the idea
                              Looking forward to having to hammer the long tubes for clearance?
                                motor mount arm clears, I will be bolting the engine up to the subframe out of the car to see how things fit there and will have them cut/welded for clearance.
                                  I collected a few brackets I needed from daggerty's parts car and had them blasted to remove the possum residue
                                    Image result for opossum
                                      Eat your hearts out, ZHP knobs!
                                      6.3 oz (179g) vs the 5.4 oz ZHP knob.
                                      Other benefits:
                                      -No undeserved //M striping.
                                      -Vegan, no animal skins, milk, eggs, or beef involved
                                      -under $15
                                        Where you be getting that?
                                          Cored out the inside and added lead
                                          I think I paid $12 for the knob brand new
