E30 M52
I got the intake cam installed and torqu... no I didnt. The last 2 stripped.
Im even using a brand new torque wrench with a certificate of calibration and everything.
Stupid 24V
Update: fixed 1 of the 3 remaining stripped holes. Tap fell and rolled somewhere. 10 minutes of sweaty searching and I quit. I'll just buy a new one and find the old one right after I start using it.
Let me also tell you of the struggle of getting a straight drill/tap with the head on the engine hanging from an engine hoist (i cannot rest it on something now because the pan is off)
This is a common occurrence on the Toyota 3VZE which is also a shitty engine
This is my lifter bucket keeper-upper so the lifters dont fall out when removing/installing the cam trays.
Steel rod with some magnets
I was going to assemble the oil pump with the E34 pickup tube but noticed a knick in the pump outer ring.
(Assembled view so you can see what part I am talking about)
This part isnt under too much stress but it gets loaded cyclically and its a perfect storm for a crack to form from fatigue+heat. If the ring opens up at all it will jam/sieze
I am ordering a new one and will replace the pressure relief valve components while im at it. I wasnt planning on it but its a Wednesday and I had KFC for dinner so I guess I will
This is the bracket for the rear-sump pickup tube. It gets bent/broken off for fitment of the front sump pan.
My progress is at a crossroads until parts arrive and there isnt too much I can do to keep moving forward so I think I will use the time to modify the shift linkage and shift carrier so i can drop them off with Mr. Welderdude.
I picked up the oil pan from him monday
Are we there yet?
Looking forward to having to hammer the long tubes for clearance?
Where you be getting that?
So you saved $50ish but gained lead poisoning...
