  4. E30 M52
E30 M52
  • The Full BananaT
    The Full BananaT
    The Full Banana
    Are we there yet?
      This E30 is not likely to be road legal in 2017. If I didn't have to finish the exhaust and re-register it I would say yes. I am doing what I can to get back to enjoying the car.
      Tom,  cool your tits, we just got Dairy Queen, DONT YOU LIKE DAIRY QUEEN!?!?!?
        Test fitting
          Mid engine swap?  At least open the door...
            I figured popping the sunroof would give me the clearance I needed but thanks for the idea
              Looking forward to having to hammer the long tubes for clearance?
                motor mount arm clears, I will be bolting the engine up to the subframe out of the car to see how things fit there and will have them cut/welded for clearance.
                  I collected a few brackets I needed from daggerty's parts car and had them blasted to remove the possum residue
                    Image result for opossum
                      Eat your hearts out, ZHP knobs!
                      6.3 oz (179g) vs the 5.4 oz ZHP knob.
                      Other benefits:
                      -No undeserved //M striping.
                      -Vegan, no animal skins, milk, eggs, or beef involved
                      -under $15
                        Where you be getting that?
                          Cored out the inside and added lead
                          I think I paid $12 for the knob brand new
                            So you saved $50ish but gained lead poisoning...
                              Dont you worry, buttercup, I wear a full Hazmat suit when I go fishing or to the gun range and I can drive my car with it too. Folks will think im the Stig!
                                It doesn't feel the same in your hand
                                Phrasing?
                                    I received a few final pieces to finish rebuilding the oil pump. The new outer rotor has a .002" larger diameter than the old one which in itself will increase/restore pump performance substantially.
                                    The overpressure relief springs had an evident difference in length and stiffness . The new one being longer and stiffer and better for preventing any early bleed-off of pressure. The new o-ring was badly needed as well.
                                    The Achillies upgraded pump shaft comes with a bolt instead of a nut, a new sprocket (has flats instead of splines, a bmw sprocket will not work on this shaft) and safety wire.
                                    I also received the little cam tray dowel I needed. Lets see if I can finally get these stupid camshafts installed this weekend
                                      Intake cam torqued
                                      Just kidding, stripped another stud.
                                        I got a wave of motivation, went out and fixed the stripped threads, re-installed the cam.
                                        Guess what happened?
                                        Yep, stripped another one!
                                          So are you sure you have the proper torque specs? I don't want to seem like I'm second guessing you but I find it very hard to believe that they would put a torque spec that dangerously close to the yield of that thread in aluminum.
