E30 M52
Looking forward to having to hammer the long tubes for clearance?
Where you be getting that?
So you saved $50ish but gained lead poisoning...
It doesn't feel the same in your hand
Phrasing?
I received a few final pieces to finish rebuilding the oil pump. The new outer rotor has a .002" larger diameter than the old one which in itself will increase/restore pump performance substantially.
The overpressure relief springs had an evident difference in length and stiffness . The new one being longer and stiffer and better for preventing any early bleed-off of pressure. The new o-ring was badly needed as well.
The Achillies upgraded pump shaft comes with a bolt instead of a nut, a new sprocket (has flats instead of splines, a bmw sprocket will not work on this shaft) and safety wire.
I also received the little cam tray dowel I needed. Lets see if I can finally get these stupid camshafts installed this weekend
