  4. E30 M52
E30 M52
    I installed my 2 helicoils. The cam trays are no fun to install. I am using a folded over strip of tape to keep the lifters from falling out but it looks like I will need to resort to using magnets.
    I have so much sweat
    • JeffJ
      JeffJ
      Jeff
      Assembly lube fixes the issue of them falling out.
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
        More stripped threads happening on the exhaust cam studs
        Im using a small in-lb beam torque wrench but am going to buy something more expensive just because this is getting ridiculous.
        • JeffJ
          JeffJ
          Jeff
          Jesus
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            The M20 would have never done this to me.
            Partly because it doesnt have bearing caps
                14590867121628019839308150775123044262
                  Seeing this makes me feel quite a bit better actually.
                    That is: AMAZING.
                      I got the intake cam installed and torqu... no I didnt. The last 2 stripped.
                      Im even using a brand new torque wrench with a certificate of calibration and everything.
                      Stupid 24V
                      Update: fixed 1 of the 3 remaining stripped holes. Tap fell and rolled somewhere. 10 minutes of sweaty searching and I quit. I'll just buy a new one and find the old one right after I start using it.
                      Let me also tell you of the struggle of getting a straight drill/tap with the head on the engine hanging from an engine hoist (i cannot rest it on something now because the pan is off)
                      This is a common occurrence on the Toyota 3VZE which is also a shitty engine
                        run it.
                          This is my lifter bucket keeper-upper so the lifters dont fall out when removing/installing the cam trays.
                          Steel rod with some magnets
                          I was going to assemble the oil pump with the E34 pickup tube but noticed a knick in the pump outer ring. 7cef1722c82b0915ffa066a43c5373be.jpg
                          (Assembled view so you can see what part I am talking about)
                          This part isnt under too much stress but it gets loaded cyclically and its a perfect storm for a crack to form from fatigue+heat. If the ring opens up at all it will jam/sieze
                          I am ordering a new one and will replace the pressure relief valve components while im at it. I wasnt planning on it but its a Wednesday and I had KFC for dinner so I guess I will
                          This is the bracket for the rear-sump pickup tube. It gets bent/broken off for fitment of the front sump pan.
                          My progress is at a crossroads until parts arrive and there isnt too much I can do to keep moving forward so I think I will use the time to modify the shift linkage and shift carrier so i can drop them off with Mr. Welderdude.
                          I picked up the oil pan from him monday
                          • JeffJ
                            JeffJ
                            Jeff
                            Nice update! I love the idea with the magnets holding the lifters.
                            1976 530i e12
                            1990 325ix e30
                            1992 325i e36
                            1995 740il e38
                            2001 330xi e46
                            ^More to come :)
                              Chugga chugga chugga. You going to be driving this to the fall meet?
                              • The Full BananaT
                                The Full BananaT
                                The Full Banana
                                Are we there yet?
                                  This E30 is not likely to be road legal in 2017. If I didn't have to finish the exhaust and re-register it I would say yes. I am doing what I can to get back to enjoying the car.
                                  Tom,  cool your tits, we just got Dairy Queen, DONT YOU LIKE DAIRY QUEEN!?!?!?
                                    Test fitting
                                      Mid engine swap?  At least open the door...
                                        I figured popping the sunroof would give me the clearance I needed but thanks for the idea
                                          Looking forward to having to hammer the long tubes for clearance?
