pistonse30
    tsweers89 said:
    Chain! Haha
    I had the machine shop do all that.
    Well thats good. But should have done that yourself. Or at least went to somewere good. haha.
    First time building a 24v and all that $$$$ into it, nah. I wanted to avoid an opps moment.
      Trying to find the motivation to climb under the car and do the driveshaft and trans/diff fluid.  I have a feeling that the guibo thing might have taken a crap.
        To fill trans fluid take out the shift boot and use a funnel with a hose from inside the car, no need to pump it in.
          Good idea!  That never crossed my mind.  That was one of the things I was dreading.
            Worked great for me, but pour it into the funnel slowly, I had a brain fart and forgot my trans only holds 1.2 qts, for some reason I was thinking 1.8, so I dumped a half quart of redline on the ground.
              MacGyver'd the crap out of that! What is the big drum on this drive shaft? It came off an '88 vert. Driveability?
                That's some awesome MacGyver-ing, looks like when I got my fan clutch off without the special tools and the big-wrench/swing a BFH method failed
                  Trans. FILL!
                  • Brian.B
                    Brian.B
                    Brian.
                    that steering wheel needs to go
                    instagram @howdoyoudrivethat
                      DrLeadFoot said:
                      Trans. FILL!
                      Glad that worked for you, how do you like the gauges on the column?  I was thinking of doing this to get rid of my a pillar pod.
                        An Evo III wheel?? You cray.
                        Trans. FILL!
                        I like them. I did the a-pillar mount years ago and I wanted to mix it up.
                        • Brian.B
                          Brian.B
                          Brian.
                          The wheel looks too modern for the car. Also, how do you fill up the trans from there? I'm just curious, as I haven't owned a manual prior to the winter E28
                            2ft of clear hose and that funnel. Pop the hose into the side fill hole and start pouring! So much easier than the pump method.
                              Brakes done. Just gotta hit them with some paint. Gold rotors??? Maybe just black.
                                dark bronze color plz
                                • Brian.B
                                  Brian.B
                                  Brian.
                                  Oh, so theres a legit fill hole that you can access through the shift boot? Wonder if my Getrag 265 has one.
                                    That looks pretty good!
                                    There isn't a fill hole through the boot. I just pulled mine up to access. You have to lead the hose to the fill hole while underneath the car. It isn't directly under the shifter.
                                      I just popped my drive shaft back in after flipping the csb around. Installed it backwards, oops.
                                      While I was down there I took some close up pics of my exhaust. They go in order of front to back. Pics are of the weld/mounting points.
                                        As she sits now. In the middle of installing the CCV.
                                        • Brian.B
                                          Brian.B
                                          Brian.
                                          Yummayyyyyy. More engine bay shots.
