pistonse30
    someone said:
    MacGyver'd the crap out of that!
    That's some awesome MacGyver-ing, looks like when I got my fan clutch off without the special tools and the big-wrench/swing a BFH method failed
      Trans. FILL!
        that steering wheel needs to go
          DrLeadFoot said:
          Trans. FILL!
          Glad that worked for you, how do you like the gauges on the column?  I was thinking of doing this to get rid of my a pillar pod.
            An Evo III wheel?? You cray.
            Trans. FILL!
            I like them. I did the a-pillar mount years ago and I wanted to mix it up.
              The wheel looks too modern for the car. Also, how do you fill up the trans from there? I'm just curious, as I haven't owned a manual prior to the winter E28
                2ft of clear hose and that funnel. Pop the hose into the side fill hole and start pouring! So much easier than the pump method.
                  Brakes done. Just gotta hit them with some paint. Gold rotors??? Maybe just black.
                    dark bronze color plz
                      Oh, so theres a legit fill hole that you can access through the shift boot? Wonder if my Getrag 265 has one.
                        That looks pretty good!
                        There isn't a fill hole through the boot. I just pulled mine up to access. You have to lead the hose to the fill hole while underneath the car. It isn't directly under the shifter.
                          I just popped my drive shaft back in after flipping the csb around. Installed it backwards, oops.
                          While I was down there I took some close up pics of my exhaust. They go in order of front to back. Pics are of the weld/mounting points.
                            As she sits now. In the middle of installing the CCV.
                              Yummayyyyyy. More engine bay shots.
                                  Doing a little wiring.
                                    Crank Case is on vacuum!
                                    Beat the crap out of her last night and she was all good!!
                                    I might have to close up the plug gap a little more and make sure all the plugs have the open side facing away from the intake so I don't blow out the spark. It slightly broke up a couple of times.
                                    I smoked a modded, newer GTO last night! Ha! Dude was shocked.
                                    Time to boost her up!!! I might go 18-22psi. I'm at 14psi now after fixing a leak I've had since the beginning.
                                      cold weather boostin'
                                      looks awesome man
                                          Car looks great John! IMO, it would look much cleaner with some black elbows for the intercooler.
