pistonse30
  • T
    T
    tsweers89
    Did I hear right that you had Kumhoe did your engine? If i would of known that I would have done it for you.
      ?? Kummrow put the head/timing belt on.
      • T
        T
        tsweers89
         s52 doesnt have a timing belt. haha. No i heard they put the motor together like block, crank, rods, pistons. etc. or did you have the machine shop do all that?
          Chain! Haha
          I had the machine shop do all that.
          • T
            T
            tsweers89
            DrLeadFoot said:
            Chain! Haha
            Well thats good. But should have done that yourself. Or at least went to somewere good. haha.
              tsweers89 said:
              Chain! Haha
              First time building a 24v and all that $$$$ into it, nah. I wanted to avoid an opps moment.
                Trying to find the motivation to climb under the car and do the driveshaft and trans/diff fluid.  I have a feeling that the guibo thing might have taken a crap.
                  To fill trans fluid take out the shift boot and use a funnel with a hose from inside the car, no need to pump it in.
                    Good idea!  That never crossed my mind.  That was one of the things I was dreading.
                      Worked great for me, but pour it into the funnel slowly, I had a brain fart and forgot my trans only holds 1.2 qts, for some reason I was thinking 1.8, so I dumped a half quart of redline on the ground.
                        MacGyver'd the crap out of that! What is the big drum on this drive shaft? It came off an '88 vert. Driveability?
                          That's some awesome MacGyver-ing, looks like when I got my fan clutch off without the special tools and the big-wrench/swing a BFH method failed
                            Trans. FILL!
                              that steering wheel needs to go
                                DrLeadFoot said:
                                Trans. FILL!
                                Glad that worked for you, how do you like the gauges on the column?  I was thinking of doing this to get rid of my a pillar pod.
                                  An Evo III wheel?? You cray.
                                  Trans. FILL!
                                  I like them. I did the a-pillar mount years ago and I wanted to mix it up.
                                    The wheel looks too modern for the car. Also, how do you fill up the trans from there? I'm just curious, as I haven't owned a manual prior to the winter E28
                                      2ft of clear hose and that funnel. Pop the hose into the side fill hole and start pouring! So much easier than the pump method.
                                        Brakes done. Just gotta hit them with some paint. Gold rotors??? Maybe just black.
                                          dark bronze color plz
