E21 Project Thread - Part 2
May bad this is the one I use it is a little different
Hmm I'm liking that that first one you posted its body is only 4" vs the 6" of the correct one. The 4" would keep it tucked up where it doesn't hang lower than the floor under the car. I'll have to ponder this.
I've been brainstorming with Brian and we thought that I could run an oval section under rear subframe so it doesn't hang as low. Trouble is I'm having a hard time finding a 2.5" transition adapter to go from round to oval. Then another to go back to round after subframe.
Were you looking for something like these?
http://www.racemufflers.com/Oval-to-Round-Transitions-s/2021.htm
Yes, but as you see the smallest size seems to always be 3". I need 2.5"
This may work ...
http://spintechmufflers.com/frame-clearance-tube-priced-each/
Will that change the sound of the exhaust at all?
It may change it some due to the way the sound waves will bounce.
There's always the side exit boom tube option
jk -
Dave, the place you posted has 2.5" round to oval too.
Yup I saw that, but figured the "frame clearance tubing" is basically what I'd be making with two round-to-oval adapters and an oval section. And it's cheaper.
Why not run a round muffler/resonator mid car, then adjust the tubing to go where it needs to?
The stock routing goes over the rear subframe, then under the half-shaft. With the work that he's done in that area, and the larger-than-stock tubing, it would be a tight squeeze. Running it under the subframe works but it's pretty close to the ground at that point. Thankfully, I raised my subframe a couple inches, so I shouldn't have this issue...
^^^ What he said
I ordered the flowmaster HP-2 resonator and am just waiting on a call from the company that makes the frame clearance tubing as they may be able to save me time and money.
Can't wait to hear those puppies, I'm think about putting them on the e38
Decided to remove the turbo and manifold to see where the exhaust leak is coming from while I wait for mandrel bent exhaust pieces to come in the mail.
This may explain why my car sounded like a diesel engine last summer. Holy exhaust leak/shitty alignment batman!!!!! Don't do eBay manifolds, just don't!
I'm picking up@snap old ceramic coated manifold and turbo adapter for piece of mind. Ordering new exhaust manifold gaskets too.
almost looks like the flange might be upside down on that manifold (which is exactly the problem with some ebay volvo manifolds too)
That's a good point. I bet you are right with that one. All I know is that it spooled pretty decently like this, so I'm anxious to find out what it does with a proper manifold.
I just won a lot of 2.5" SS mandrel bent pipe on eBay consisting of 2 180 bends, 1 45 bend and 4 90 bends all for $35 plus shipping. Should be plenty for what i need to make my exhaust.
