    Planning on sticking with the 2.5"
    • JeffJ
      JeffJ
      Jeff
      These things sound amazing and are not very loud. I have 1 3" one on my e36 and it is quiet when cruising and wakes up at WOT. No drone is also a big bonus
      Shorter one
      https://m.summitracing.com/parts/flo-12512409
      Longer
      https://m.summitracing.com/parts/flo-12518409
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
      • JeffJ
        JeffJ
        Jeff
        May bad this is the one I use it is a little different
        https://m.summitracing.com/parts/flo-13012100
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
          Hmm I'm liking that that first one you posted its body is only 4" vs the 6" of the correct one. The 4" would keep it tucked up where it doesn't hang lower than the floor under the car. I'll have to ponder this.
          I've been brainstorming with Brian and we thought that I could run an oval section under rear subframe so it doesn't hang as low. Trouble is I'm having a hard time finding a 2.5" transition adapter to go from round to oval. Then another to go back to round after subframe.
            Were you looking for something like these?
            http://www.racemufflers.com/Oval-to-Round-Transitions-s/2021.htm
              Yes, but as you see the smallest size seems to always be 3". I need 2.5"
                This may work ...
                http://spintechmufflers.com/frame-clearance-tube-priced-each/
                  Will that change the sound of the exhaust at all?
                  • JeffJ
                    JeffJ
                    Jeff
                    I like the idea of an oval section, it will give you tons of clearance
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                    • JeffJ
                      JeffJ
                      Jeff
                      It may change it some due to the way the sound waves will bounce.
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        There's always the side exit boom tube option 😛 jk
                          Dave, the place you posted has 2.5" round to oval too.
                          http://spintechmufflers.com/straight-line-transitions/
                            Yup I saw that, but figured the "frame clearance tubing" is basically what I'd be making with two round-to-oval adapters and an oval section. And it's cheaper.
                              https://www.summitracing.com/parts/mpe-10416?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-magnaflow&gclid=CMaW0YehgtUCFcS4wAodUDkHvA
                              Why not run a round muffler/resonator mid car, then adjust the tubing to go where it needs to?
                                The stock routing goes over the rear subframe, then under the half-shaft. With the work that he's done in that area, and the larger-than-stock tubing, it would be a tight squeeze. Running it under the subframe works but it's pretty close to the ground at that point. Thankfully, I raised my subframe a couple inches, so I shouldn't have this issue... 😒
                                  ^^^ What he said
                                  I ordered the flowmaster HP-2 resonator and am just waiting on a call from the company that makes the frame clearance tubing as they may be able to save me time and money.
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    Bassboy3313 said:
                                    Can't wait to hear those puppies, I'm think about putting them on the e38
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                      Decided to remove the turbo and manifold to see where the exhaust leak is coming from while I wait for mandrel bent exhaust pieces to come in the mail.
                                      This may explain why my car sounded like a diesel engine last summer. Holy exhaust leak/shitty alignment batman!!!!! Don't do eBay manifolds, just don't!
                                      I'm picking up@snap old ceramic coated manifold and turbo adapter for piece of mind. Ordering new exhaust manifold gaskets too. 606de225c0a74df03426ceaa7dc15f2f.jpg7276fe8bf18379821be844f294a8aef6.jpg7fb11cca98d79ba15f3a1fd00622f13b.jpg
                                      • JeffJ
                                        JeffJ
                                        Jeff
                                        That is an impressive amount of misalignment!
                                        1976 530i e12
                                        1990 325ix e30
                                        1992 325i e36
                                        1995 740il e38
                                        2001 330xi e46
                                        ^More to come :)
                                        • The Full BananaT
                                          The Full BananaT
                                          The Full Banana
                                          almost looks like the flange might be upside down on that manifold (which is exactly the problem with some ebay volvo manifolds too)
