    uggghhh that looks annoying. Mostly because mine is all painted and its seems yours is too.. Please get someone to help you put it back in the car. I know all to well how annoying it is by yourself on the ground. 😦
      uggghhh that looks annoying. Mostly because mine is all painted and its seems yours is too.. Please get someone to help you put it back in the car. I know all to well how annoying it is by yourself on the ground. [emoji20]
      It wasn't that bad at all. The nice thing about the e21 is that the subframe mounts unbolt from the subframe. So I install the mounts on the frame studs loosely. Then roll assembly underneath, jack it up and bolt the subframe to the mounts after getting them lined up.
      The thing I'm running into now tho is that with the subframe mounted, jacking up the diff puts it at an angle that the mount arms I welded on the car doesn't like. Somehow I need to pull the rear side of mounts towards rear of car about an 1/8th for the diff cover to clear them. I'm thinking maybe rent a slide hammer from AAP and give it a few whacks. That's my best idea. 837f5c777df364622af5e59c78454066.jpg
        rear end is back in the car, camber adjustments arbitrarily set to the middle and is already way better than before. I'm in the process of torquing all bolts to spec and just have the driveshaft to diff, axle castle nuts and toe adjustments bolts to torque down. I need to do either some clearancing to the subframe mount plate or make a custom wrench in order to tighten/adjust the tow bolt. Between the subframe bushing mount bolt and the mounting plate, makes it impossible to get a normal wrench on the bolt. Once that's all done, just gotta fill diff with fluid and *crossing fingers* everything should finally be done and I can move onto engine stuff.
          NOICE!!! Engine stuff is the best stuff. Glad you are getting/got the subframe sorted. +1 points for you sir.
            Haven't had ANY time to work on this thing the last few weeks. I finally got the front wheels/tires on and my old setup sold to recoup some cash. All that is left on the rear end is to fill the diff with fluid and bolt up the driveshaft to the diff.
            I have been brainstorming exhaust ideas and not sure what I will do yet. One thought is side exit right in front of the rear wheel, but I would want it to be super quiet which seems hard for a side exit. The reason I consider it is because with the new e30 diff conversion, I no longer can route the exhaust above the subframe, it must go underneath, which I am afraid will hang too low for comfort. Just brainstorming right now. I guess I won't know until I get the car up and look underneath again.
            • JeffJ
              JeffJ
              Jeff
              What size exhaust pipe are you thinking of running?
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
                Planning on sticking with the 2.5"
                • JeffJ
                  JeffJ
                  Jeff
                  These things sound amazing and are not very loud. I have 1 3" one on my e36 and it is quiet when cruising and wakes up at WOT. No drone is also a big bonus
                  Shorter one
                  https://m.summitracing.com/parts/flo-12512409
                  Longer
                  https://m.summitracing.com/parts/flo-12518409
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                  • JeffJ
                    JeffJ
                    Jeff
                    May bad this is the one I use it is a little different
                    https://m.summitracing.com/parts/flo-13012100
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      Hmm I'm liking that that first one you posted its body is only 4" vs the 6" of the correct one. The 4" would keep it tucked up where it doesn't hang lower than the floor under the car. I'll have to ponder this.
                      I've been brainstorming with Brian and we thought that I could run an oval section under rear subframe so it doesn't hang as low. Trouble is I'm having a hard time finding a 2.5" transition adapter to go from round to oval. Then another to go back to round after subframe.
                        Were you looking for something like these?
                        http://www.racemufflers.com/Oval-to-Round-Transitions-s/2021.htm
                          Yes, but as you see the smallest size seems to always be 3". I need 2.5"
                            This may work ...
                            http://spintechmufflers.com/frame-clearance-tube-priced-each/
                              Will that change the sound of the exhaust at all?
                              • JeffJ
                                JeffJ
                                Jeff
                                I like the idea of an oval section, it will give you tons of clearance
                                1976 530i e12
                                1990 325ix e30
                                1992 325i e36
                                1995 740il e38
                                2001 330xi e46
                                ^More to come :)
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  It may change it some due to the way the sound waves will bounce.
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                    There's always the side exit boom tube option 😛 jk
                                      Dave, the place you posted has 2.5" round to oval too.
                                      http://spintechmufflers.com/straight-line-transitions/
                                        Yup I saw that, but figured the "frame clearance tubing" is basically what I'd be making with two round-to-oval adapters and an oval section. And it's cheaper.
                                          https://www.summitracing.com/parts/mpe-10416?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-magnaflow&gclid=CMaW0YehgtUCFcS4wAodUDkHvA
                                          Why not run a round muffler/resonator mid car, then adjust the tubing to go where it needs to?
