  • JeffJ
    JeffJ
    Jeff
    What size exhaust pipe are you thinking of running?
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
      Planning on sticking with the 2.5"
      • JeffJ
        JeffJ
        Jeff
        These things sound amazing and are not very loud. I have 1 3" one on my e36 and it is quiet when cruising and wakes up at WOT. No drone is also a big bonus
        Shorter one
        https://m.summitracing.com/parts/flo-12512409
        Longer
        https://m.summitracing.com/parts/flo-12518409
        1976 530i e12
        1990 325ix e30
        1992 325i e36
        1995 740il e38
        2001 330xi e46
        ^More to come :)
        • JeffJ
          JeffJ
          Jeff
          May bad this is the one I use it is a little different
          https://m.summitracing.com/parts/flo-13012100
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
            Hmm I'm liking that that first one you posted its body is only 4" vs the 6" of the correct one. The 4" would keep it tucked up where it doesn't hang lower than the floor under the car. I'll have to ponder this.
            I've been brainstorming with Brian and we thought that I could run an oval section under rear subframe so it doesn't hang as low. Trouble is I'm having a hard time finding a 2.5" transition adapter to go from round to oval. Then another to go back to round after subframe.
              Were you looking for something like these?
              http://www.racemufflers.com/Oval-to-Round-Transitions-s/2021.htm
                Yes, but as you see the smallest size seems to always be 3". I need 2.5"
                  This may work ...
                  http://spintechmufflers.com/frame-clearance-tube-priced-each/
                    Will that change the sound of the exhaust at all?
                    • JeffJ
                      JeffJ
                      Jeff
                      I like the idea of an oval section, it will give you tons of clearance
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                      • JeffJ
                        JeffJ
                        Jeff
                        It may change it some due to the way the sound waves will bounce.
                        1976 530i e12
                        1990 325ix e30
                        1992 325i e36
                        1995 740il e38
                        2001 330xi e46
                        ^More to come :)
                          There's always the side exit boom tube option 😛 jk
                            Dave, the place you posted has 2.5" round to oval too.
                            http://spintechmufflers.com/straight-line-transitions/
                              Yup I saw that, but figured the "frame clearance tubing" is basically what I'd be making with two round-to-oval adapters and an oval section. And it's cheaper.
                                https://www.summitracing.com/parts/mpe-10416?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-magnaflow&gclid=CMaW0YehgtUCFcS4wAodUDkHvA
                                Why not run a round muffler/resonator mid car, then adjust the tubing to go where it needs to?
                                  The stock routing goes over the rear subframe, then under the half-shaft. With the work that he's done in that area, and the larger-than-stock tubing, it would be a tight squeeze. Running it under the subframe works but it's pretty close to the ground at that point. Thankfully, I raised my subframe a couple inches, so I shouldn't have this issue... 😒
                                    ^^^ What he said
                                    I ordered the flowmaster HP-2 resonator and am just waiting on a call from the company that makes the frame clearance tubing as they may be able to save me time and money.
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      Bassboy3313 said:
                                      Can't wait to hear those puppies, I'm think about putting them on the e38
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                        Decided to remove the turbo and manifold to see where the exhaust leak is coming from while I wait for mandrel bent exhaust pieces to come in the mail.
                                        This may explain why my car sounded like a diesel engine last summer. Holy exhaust leak/shitty alignment batman!!!!! Don't do eBay manifolds, just don't!
                                        I'm picking up@snap old ceramic coated manifold and turbo adapter for piece of mind. Ordering new exhaust manifold gaskets too. 606de225c0a74df03426ceaa7dc15f2f.jpg7276fe8bf18379821be844f294a8aef6.jpg7fb11cca98d79ba15f3a1fd00622f13b.jpg
                                        • JeffJ
                                          JeffJ
                                          Jeff
                                          That is an impressive amount of misalignment!
                                          1976 530i e12
                                          1990 325ix e30
                                          1992 325i e36
                                          1995 740il e38
                                          2001 330xi e46
                                          ^More to come :)
