    removing the wiper linkage and motor?
    ever try and solve one of these? pretty much the same task.Clever-font-b-Link-b-font-Ring-Wire-font-b-Puzzle-b-font-Gadget-Chinese-Metal.jpg
    maybe just add some sort of additional black plastic/rubber washer that is larger and covers the elongated hole instead? i don't like shortcuts, but sometimes personal sanity needs to be a consideration when working on cars [emoji3]
    Hahaha I figured as much. Normally I would be all for just covering the hole if it meant keeping my sanity, but unfortunately it is also bent downwards (hard to see in the picture, you can see the windshield seal isnt sitting flat) so its pretty much a big dent. Given your analogy, Ill probably save this task for when I pull the engine, since I'd have to remove half of it to get that thing out anyway...
      We swapped out Sams with minimal trouble. However, he car does not have a blower motor lol
        The sawzall and angle grinder I was going to borrow to start cutting the front off the car are being used by my dad at the moment so I have been working on some other projects.
        My garage is not heated and with temperatures dropping (especially now) I don't have a way to be able to paint parts. Instead of heating my entire garage in order to paint something I decided to make an "oven" that I can use to keep the paint and part warm before spraying and also allow the paint to cure properly. It is a 3'x2'x2' box made of 1" foam board insulation and just held together with a ton of duct tape:
        It is big enough that I can fit most things that I will need to paint this winter. There are two incandescent light bulbs to provide the heat, I used "rough" bulbs as they have a thicker filament that emits more heat than a standard bulb of the same wattage (dimmer light output = more heat output). The lights are connected to a control box that I built. It uses a small thermostat commonly found in home brewing setups to flip a relay that switches the lights on and off depending on the internal temperature. The thermostat reads the internal temperature from a thermocouple inside the center of the box. I programmed the thermostat and did some trial runs today and it works very well, it should save me a lot of money compared to heating the whole garage just to paint things. The whole setup cost me less than $60.
        I got the rear brakes pulled from the trailing arms and started the rebuild process on the calipers. I received the fronts already disassembled and started breaking down the rears. Got new rotors for the front and the rears look really new so I'm just going to clean them up and run them. Also rebuilt my driver's door lock as it hasn't been working as long as I owned the car.
          Finally got all the AC parts out of the way and took a bunch of measurements detailing the core support location, frame rail dimensions, etc. With nothing else in the way I busted out the sawzall and passed the point of no return...
          Before:
          After:
            that must have been a bit terrifying!
              Having never done this before, the first cut was definitely a little scary
                It's 8 million times easier to do engine things now.....sooooooo you might as well pull it and freshen it up
                  lots of elbow room for fitting FI piping too
                    6b21ef9c17d96b863db2bd496c0e3b799fb5623e
                    ^ This is how I felt the moment the core support was out of the way... I might even be able to pull the engine without a hoist at this point, just lower it and wheel it out on a dolly...
                      Even easier thing would be to set the front subframe and trans brace on stands/blocks, unbolt them both, then lift up the front of the car by hand (it's light enough) and push it backwards like a wheel barrow 😃
                        Light enough? Jesus earl. You on a diet of spinach only?
                        • andyhundleyA
                          andyhundleyA
                          andyhundley
                          Earl is the Incredible Hulk. Spot him and he'll left your house.
                            Earl lifts my soul
                              Earl lifts my soul
                              When did you buy a Kia?
                                Earl is right I can pick up the front of my sedan shell and move it like a wheelbarrow.
                                  I used to do it to the compact so I figured the e30 would be a little lighter haha.
                                    You both must pick things up and put them down a lot
                                      I'll have to give lifting it a shot haha... I think the right thing to do is pull the motor now since its so much less work in the long run. My goal of back on the road by spring might not happen but it will be totally worth it.
                                        Going through and doing all of the seals on an m42 does take long as long as you aren't repainting absolutely everything...lol
                                          I probably won't be going as in depth as you have haha. Just planning to fix some leaks and repaint a lot of the major stuff so it looks nicer. I'm mostly planning to work on the engine bay, since it'll be easier to pull the wiper linkage and fix the cowl damage, run new brake lines to delete the ABS pump, and generally clean up the whole thing since it's pretty nasty.
