  4. '88 E30
'88 E30
savebigmoney
    pads I went with HT-10 and Street Race
    78mm motorsport hardware
    stainless front lines
      DrLeadFoot said:
      Royal purple has not helped my zf trans at all. Feels like the synchros aren't there sometimes. (From what I remember)
      That's what I'm saying, Royal Purple pretty much didn't let my zf go into gear when it was below 40 degrees outside. Redline completely fixed that.
        i'll swap it out, i dont think ive ever driven my car when its been that cold with the current fluid.
        im excited to now have butter smooth shifts & get all the bitties
          Did some reading. Lightbulb clicked. Went outside. Realized the CSB is on incorrectly. Hated myself for a bit. Ordered new CSB. Now I get to drop the driveshaft again.
          Totally not happy about that. Guess I was in a rush to put it back on and wasn't thinking, I blame spotted cow & the Internet
            Mmm da cow. I tried the RP synchromax in my g250 it didn't seem right. Everything worked but when I switched to recline half gear oil and half atf that is recommended by UUC with a light flywheel it felt much better.
              Hahaha! The internet
              I switched out redline for lucas in my g260 and it was a definite immediate downgrade in shiftyness
                Got the driveshaft out in about .3 seconds (kind of surprised) and ripped the CSB off of it and made notes with sharpie so i dont forget the orientation for when the new one shows up (nothing was "wrong" with it, but $40 is cheap insurance)
                Also just ordered adjustable front end links not from ireland engineering
                  I Have also yet to find a place locally that sells Red Line fluids --off to the internet for those as well.
                  Called a bunch of shops to see who can weld my coils. I just got a bunch of confused responses on the phone
                  "You want to do what with your who, who is this? What are you suspensions doing with a welder?"
                    redline fluids = Pegasus racing, they are here in new germany in case you plan on coming to the mke area again sometime soon
                      Pegasus... dangerous candy store to have so close by.
                        We have zero shops like that up here
                          Stud conversion and adjustable front endlinks are here. Brake pads, stainless lines, center support bearing, diff drain plugs, redline fluids are on their way.
                          Just ordered coils as well 10K/12K
                            Only thing left to show up are the coils
                            Pads/lines/CSB/diff plugs showed up today
                            As well as this gem front Blunttech
                            Also I lied, I have ate brake fluid&redline MTL showing up soon too. I was trolling craigslist in my area for shits and giggles and came across an ad for 2qts of redline 75w-90 and 2 gallons of BMW coolant. Guy wanted $50 for everything so I bought those as well-extra coolant isn't a bad thing to have on hand
                            • JeffJ
                              JeffJ
                              Jeff
                              That be a nice pile o parts rolls
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                                Jerf is back!
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  Lol back again for a bit I hope time has not been permitting between work and home.
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                    cock-and-ball bearing?
                                      Remember, if you preload the csb more than once its considered playing with your driveshaft
                                        What coils did you go with?
                                          BC, 10k front 12k rear
