  4. '88 E30
'88 E30
savebigmoney
    wasnt m3 said:
    Not sure if you guys are changing transmission fluid as well, but I have found that red line fluid works infinitely better in bmw transmissions over royal purple.
    Royal purple has not helped my zf trans at all. Feels like the synchros aren't there sometimes. (From what I remember)
      pads I went with HT-10 and Street Race
      78mm motorsport hardware
      stainless front lines
        That's what I'm saying, Royal Purple pretty much didn't let my zf go into gear when it was below 40 degrees outside. Redline completely fixed that.
          i'll swap it out, i dont think ive ever driven my car when its been that cold with the current fluid.
          im excited to now have butter smooth shifts & get all the bitties
            Did some reading. Lightbulb clicked. Went outside. Realized the CSB is on incorrectly. Hated myself for a bit. Ordered new CSB. Now I get to drop the driveshaft again.
            Totally not happy about that. Guess I was in a rush to put it back on and wasn't thinking, I blame spotted cow & the Internet
              Mmm da cow. I tried the RP synchromax in my g250 it didn't seem right. Everything worked but when I switched to recline half gear oil and half atf that is recommended by UUC with a light flywheel it felt much better.
                Hahaha! The internet
                I switched out redline for lucas in my g260 and it was a definite immediate downgrade in shiftyness
                  Got the driveshaft out in about .3 seconds (kind of surprised) and ripped the CSB off of it and made notes with sharpie so i dont forget the orientation for when the new one shows up (nothing was "wrong" with it, but $40 is cheap insurance)
                  Also just ordered adjustable front end links not from ireland engineering
                    I Have also yet to find a place locally that sells Red Line fluids --off to the internet for those as well.
                    Called a bunch of shops to see who can weld my coils. I just got a bunch of confused responses on the phone
                    "You want to do what with your who, who is this? What are you suspensions doing with a welder?"
                      redline fluids = Pegasus racing, they are here in new germany in case you plan on coming to the mke area again sometime soon
                        Pegasus... dangerous candy store to have so close by.
                          We have zero shops like that up here
                            Stud conversion and adjustable front endlinks are here. Brake pads, stainless lines, center support bearing, diff drain plugs, redline fluids are on their way.
                            Just ordered coils as well 10K/12K
                              Only thing left to show up are the coils
                              Pads/lines/CSB/diff plugs showed up today
                              As well as this gem front Blunttech
                              Also I lied, I have ate brake fluid&redline MTL showing up soon too. I was trolling craigslist in my area for shits and giggles and came across an ad for 2qts of redline 75w-90 and 2 gallons of BMW coolant. Guy wanted $50 for everything so I bought those as well-extra coolant isn't a bad thing to have on hand
                              • JeffJ
                                JeffJ
                                Jeff
                                That be a nice pile o parts rolls
                                1976 530i e12
                                1990 325ix e30
                                1992 325i e36
                                1995 740il e38
                                2001 330xi e46
                                ^More to come :)
                                  Jerf is back!
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    Lol back again for a bit I hope time has not been permitting between work and home.
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                      cock-and-ball bearing?
                                        Remember, if you preload the csb more than once its considered playing with your driveshaft
                                          What coils did you go with?
