  4. '88 E30
'88 E30
savebigmoney
    I Have also yet to find a place locally that sells Red Line fluids --off to the internet for those as well.
    Called a bunch of shops to see who can weld my coils. I just got a bunch of confused responses on the phone
    "You want to do what with your who, who is this? What are you suspensions doing with a welder?"
      redline fluids = Pegasus racing, they are here in new germany in case you plan on coming to the mke area again sometime soon
        Pegasus... dangerous candy store to have so close by.
          We have zero shops like that up here
            Stud conversion and adjustable front endlinks are here. Brake pads, stainless lines, center support bearing, diff drain plugs, redline fluids are on their way.
            Just ordered coils as well 10K/12K
              Only thing left to show up are the coils
              Pads/lines/CSB/diff plugs showed up today
              As well as this gem front Blunttech
              Also I lied, I have ate brake fluid&redline MTL showing up soon too. I was trolling craigslist in my area for shits and giggles and came across an ad for 2qts of redline 75w-90 and 2 gallons of BMW coolant. Guy wanted $50 for everything so I bought those as well-extra coolant isn't a bad thing to have on hand
              • JeffJ
                JeffJ
                Jeff
                That be a nice pile o parts rolls
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                  Jerf is back!
                  • JeffJ
                    JeffJ
                    Jeff
                    Lol back again for a bit I hope time has not been permitting between work and home.
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                      cock-and-ball bearing?
                        Remember, if you preload the csb more than once its considered playing with your driveshaft
                          What coils did you go with?
                            BC, 10k front 12k rear
                              Tricked myself into working on my car for 5 minutes
                              Got the DS back together with a new CSB. (Old one was installed incorrectly) -don't believe the Internet about installing the CSB "backwards" they are offset and put an angle on the DS at the CSB. I took a bunch of pics for the next thread I see about installing these backwards when using a 24v swap DS.
                              Also drained the old diff fluid
                              Went to put new drain plugs in. And I don't have an Allen wrench in size massive. So I need to go pick up a new wrench tomorrow so I can tighten it and put the redline 75w-90 in
                                Put a bolt in it and a nut on the bolt, then use a socket to tighten it
                                  or
                                  i go get the right size allen wrench
                                    To be fair, earls idea is pretty slick and the next time there is a worldwide macho allen shortage I will try to remember it
                                      It is a nifty idea. But I'm probably in the same boat as I don't have a bolt that exact size
                                        So went to Sears and some other places. Nobody had an Allen that large. So I just bought a bolt and a few nuts. Gonna use the earl method.
                                          A hex socket set would probably have the right size, you can buy the gear wrench set at Sears or Advance Auto.
