  4. '88 E30
'88 E30
savebigmoney
    Mmm da cow. I tried the RP synchromax in my g250 it didn't seem right. Everything worked but when I switched to recline half gear oil and half atf that is recommended by UUC with a light flywheel it felt much better.
      Hahaha! The internet
      I switched out redline for lucas in my g260 and it was a definite immediate downgrade in shiftyness
        Got the driveshaft out in about .3 seconds (kind of surprised) and ripped the CSB off of it and made notes with sharpie so i dont forget the orientation for when the new one shows up (nothing was "wrong" with it, but $40 is cheap insurance)
        Also just ordered adjustable front end links not from ireland engineering
          I Have also yet to find a place locally that sells Red Line fluids --off to the internet for those as well.
          Called a bunch of shops to see who can weld my coils. I just got a bunch of confused responses on the phone
          "You want to do what with your who, who is this? What are you suspensions doing with a welder?"
            redline fluids = Pegasus racing, they are here in new germany in case you plan on coming to the mke area again sometime soon
              Pegasus... dangerous candy store to have so close by.
                We have zero shops like that up here
                  Stud conversion and adjustable front endlinks are here. Brake pads, stainless lines, center support bearing, diff drain plugs, redline fluids are on their way.
                  Just ordered coils as well 10K/12K
                    Only thing left to show up are the coils
                    Pads/lines/CSB/diff plugs showed up today
                    As well as this gem front Blunttech
                    Also I lied, I have ate brake fluid&redline MTL showing up soon too. I was trolling craigslist in my area for shits and giggles and came across an ad for 2qts of redline 75w-90 and 2 gallons of BMW coolant. Guy wanted $50 for everything so I bought those as well-extra coolant isn't a bad thing to have on hand
                    • JeffJ
                      JeffJ
                      Jeff
                      That be a nice pile o parts rolls
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        Jerf is back!
                        • JeffJ
                          JeffJ
                          Jeff
                          Lol back again for a bit I hope time has not been permitting between work and home.
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                            cock-and-ball bearing?
                              Remember, if you preload the csb more than once its considered playing with your driveshaft
                                What coils did you go with?
                                  BC, 10k front 12k rear
                                    Tricked myself into working on my car for 5 minutes
                                    Got the DS back together with a new CSB. (Old one was installed incorrectly) -don't believe the Internet about installing the CSB "backwards" they are offset and put an angle on the DS at the CSB. I took a bunch of pics for the next thread I see about installing these backwards when using a 24v swap DS.
                                    Also drained the old diff fluid
                                    Went to put new drain plugs in. And I don't have an Allen wrench in size massive. So I need to go pick up a new wrench tomorrow so I can tighten it and put the redline 75w-90 in
                                      Put a bolt in it and a nut on the bolt, then use a socket to tighten it
                                        or
                                        i go get the right size allen wrench
                                          To be fair, earls idea is pretty slick and the next time there is a worldwide macho allen shortage I will try to remember it
