  4. '88 E30
'88 E30
    Got everything coated in por-15
    I will be top coating it with some enamel to get some areas and for more protection
    Pics or it didn't happen
    This stuff is a pain in the ass and I'm glad I'm done
    Next step is ordering parts
    • CMartC
      CMartC
      CMart
      Brush or spray?
      Excursion 7.3
      E30 LS1
        CMart said:
        Brush or spray?
        Foam brushes
        I'll be top coating it with an enamel spray as well
          Looks good!  My front subframe and other stuff will be getting this treatment soon.  What's up with the coil overs?
            Got the topcoats on all the stuff today. Went with a gloss enamel. Put a shit load on it. Also under coated my car, it probably won't dry correctly. Also took the rack "apart"
            It looked dicked at first, but it was fine after I cleaned it up. Added some grease on the teeth, took the ps block off back off, drained the crap, added more crap, worked the rack back and forth to get the excess out then put the delete plate back on ff812ae590c0ff9ca26f581a2e84a55e.jpgf0b4a459eb82928980bb7597ecf2edfa.jpg51e5458720b7c1ecc1abce04a62c82e1.jpg784147839311a06df4edd5219264b31e.jpg
            Getting the struts ready for coils.
            Also whoever put the inner tierods in hulk-moded them. Vice grips + hammer + swearing and they barely came off. Lock plates were all farked by whoever installed them. It sucked
            Also aligned my door and fender so it didn't look all borked
            Also found some evidence of assholes in an air box(not my vehicle)...After I found acorns in my glovebox and kick panel.
            Set a bunch of traps and left out some coolant for them. I hate rodents
              Diff cover is now a color
                Son, I am disappoint.
                Didnt mask the hardware, diff tag, or the vent tube
                Good luck getting "Best In Show" this year
                  I could sand it off maybe. I didn't clean up the hardware so it's not going to stick well anyways.
                  Couldn't read the diff tag either
                  Oh
                  And it'll be under the car
                  So
                  Eat
                  Shit
                  Snap
                    Isn't that way more work than taping it off in the first place? [emoji14]
                      Compared to taping off individual bolts a vent tube and a diff tag?
                      What was the oem color the bolts should be?
                      #showseason2018
                        Grab some SS bolts to replace them and done!
                          Good idea, but i don't care to buy bolts when the ones in there now work fine
                            "Why buy new when slightly used will do?"
                            Unmasked bolts are like unfolded side mirrors during proper winter storage mode.
                            You should always mask your bolt
                              Got all the bushings in
                              That's pretty much it
                              Found out I'll need to move the union a tad
                                well it happened, ordered about $1650 worth of crap tonight for it. (will get about $160 back in core)
                                Still remaining to buy:
                                coil overs
                                brake pads & fluid (still on the fence about pads)
                                front stainless brake lines
                                  What did you buy?
                                  • CMartC
                                    CMartC
                                    CMart
                                    coil overs
                                    Not sure if I asked/you answered, but any interest in my coilover setup or coilover/bbk setup
                                    Excursion 7.3
                                    E30 LS1
                                      coil overs
                                        wasnt m3 said:
                                        What did you buy?
                                        Inner/outer tierods
                                        Boots
                                        Clamps
                                        Lock plates
                                        Control arms
                                        Wheel bearings
                                        Wheel bearing circlips
                                        Axle lock plates
                                        Axle nuts
                                        Wheel bearings
                                        Brembo blanks
                                        Calipers
                                        Skid plate
                                        ST sways
                                        Akg sway bar mount reinforcement
                                        Dust shields
                                          coil overs
                                          I didn't even know you had stuff. Just bought brakes/calipers too.......
